Error message when exporting to PDF (AutoCad 2016)
 I have been using this program and exporting the files to PDF. I was able to do this to 20 documents without problem. Now, however, I'm receiving an error message when I try to export the file. I have been trying to follow threads with similar issues, but I still am not entirely sure how to correct this. I have gone to page setup but I do not know what to do from there. I would appreciate any solutions with the disclaimer that I am not very familiar with this program or the technical language of it. Thank you.
pendean
Community Legend
Community Legend
Change "what to print" from Display to something more definitive/precise and see if your problem goes away. I also see you are missing your plot style table too.
john.vellek
Hi @Anonymous,
I suggest that you define one or more Page Setups that define all your plot configuration settings so they can be quickly and consistently applied to your drawings when you want to print or Save to PDF.
Here is a prior post that might help you.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or @pendean's helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Yes those both helped, thank you! On page setup, I changed it back to the default settings so it had a plot location. Thanks for the help!
