error message and shutting down unexpectedly
qbradesign
Message 1 of 11
qbradesign
Even though my computer is up to date, AutoCAD for Mac keeps giving an error message every 3-5 minutes and shutting down unexpectedly. Sometimes it closes without having time to autosave.
Replies (10)
Message 2 of 11
maxim_k
Hi @qbradesign ,
Please specify your AutoCAD version and macOS installed on your Mac.
Do you have Autosave enabled in AutoCAD?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 11
qbradesign
All versions are latest and updated. Also autosave is enabled.
Message 4 of 11
maxim_k
@qbradesign ,
Where do you save your drawings?
Do you save them to the iCloud enabled folder on your Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 11
marcomvalle
Observer
Observer
Hello, I have the same problem,  it happens more on my laptop than on my desktop. on both computers I save to the cloud.
Message 6 of 11
maxim_k
@marcomvalle wrote:
..... on both computers I save to the cloud.
I think this could be the problem. Try working with files in a folder that is not synced with iCloud. Are you still seeing crashes?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 11
qbradesign
No I don’t use cloud. I work and save on desktop folder. This problem started at 2025
Message 8 of 11
paullimapa
So as a test if you install older versions like 2024 on your Mac would the problem go away?
Paul Li
IT Specialist
@The Office
Message 9 of 11
marcomvalle
Observer
Observer
Hi, downgrades require some extra work, but I am almost sure the upgrade to Sequoia ruined autocad on my laptop, I hadn’t had any problems on my laptop since November when I had bought it and just purchased autocad, I did the update a couple weeks ago and now the program crashes. So Autodesk needs to work on this. I have Ventura on my desktop and autocad doesn’t crash.
Message 10 of 11
qbradesign
I tried 2024 version and had same problem.
Message 11 of 11
qbradesign
I definitely agree with this comment. This problem occurred after the Sequoia update. Autodesk should make a fix according to the latest macos update.
