Equal Spacing between objects/blocks
Please how can I equally space these rectangular objects. I want a 1 inch vertical and horizontal spacing between the blocks.
Also, when I copy a block, how do I paste it at a specific distance.
Thanks!!
maxim_k
Hi Aishatu,
You can create rectangular array from the blocks:
http://help.autodesk.com/view/ACDMAC/2018/ENU/index.html?guid=GUID-EBC5DEB0-3F18-4821-9940-561FBD8AA...
By default it will be dynamic array and you will be able to control it properties in the Properties Palette (number of columns/rows, distances, etc.) even after creation. If you don't need it to be array after you adjust everything, you can use EXPLODE command to explode the array to individual blocks.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
