Entering lines in surveyors units
Johnh57
Johnh57
I'm having a minor problem entering site survey information.   If I click at a random point in the drawing to start a line, enter a length in decimal feet, tab to the angle and enter an angle in surveyors units.  It draws the line - but in a mirror image of what I want.   For example the line I just entered was 252.80' with a bearing of S00d10'15"W.   It draws the line, but if I look at properties it shows the line as being the correct length but with a bearing of N00d10'15"W.  Which is a mirror image of the line I want.  It has changed the S to N, but kept the W designation.
If I draw the line using N00d10'15"E  it is correct.   So it seems that one must use the N designation for bearing, which is somewhat inconvenient for following a survey around a series of lines and bearings.
what am I missing here?
0 Me gusta
Responder
Soluciones aceptadas (1)
2.421 Vistas
5 Respuestas
Respuestas (5)
maxim_k
I have this settings for units:
and cannot reproduce your problem.
Check "Base angle directions" setting.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Johnh57
Interesting.  My setup is exactly as yours - except I do not have anything selected for 'light intensity'
0 Me gusta
maxim_k
Can you attach sample drawing in which you have this problem?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
0 Me gusta
Johnh57
Solución aceptada
hmm, opened the file that was causing trouble, deleted some details that were not relevant, and could not reproduce the problem.  The lines go in exactly as entered.
Opened up the specific file that was having trouble and entered length and bearings - no problems.
I've seen this before, I've learned to double check the bearings on lines entered to make sure they show up as entered and not mirrored.
Problem solved I guess.
