hi,
I've tried student and trial version of autocad 2015/2016/2017 but every time I use edit page in layout and set the paper size the program crash. I've OS X Sierra 10.12.2.
these are the error message and the files generated.
Solved by maxim_k. Go to Solution.
hi,
I tried many times to do different settings, but even if I do not change any settings in the edit page the program crashes. so every time I open the edit page program crashes.
I am hopeful in your help. 🙂
thanks
Have you seen the suggestion made here: https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
hi,
I've seen the suggestion, but in my mac I have no printers installed and do not have the font specified in the link.
I tried both, but the program crashes even if I do not change any of 'edit page setting. that is, just open edit page and close it again ("ok" or "cancel") to crash the program
If you are in trouble how to install printer software without hardware, here is an article from Autodesk Knowledge Base:
"To install a printer driver on Mac for which you don't actually have the physical device, follow these steps:
In Printers & Scanners, you'll now have a printer called 127.0.0.1, which can be selected when you plot from AutoCAD. Selecting the device will give you access to its paper sizes, which can be used when saving as PDF."
Maxim
I am having the exact same problem and am on the same Mac software as you. Did you manage to get the problem resolved? If so, how?
