Distorted 3D (ORTHO) view when plotting to PDF
No aplicable
... and possibly to printer, but unable to test.
Look closely at the (longer) pipe runs. The edges are intermittent!
The object in question is a 3D solid. As may be seen in the screenshot, the pipe looks fine in pspace.
(I've already checked: this is not a discontinuous linetype set to a bizarrely large scale. Also played with various plot styles & settings).
0 Me gusta
Responder
768 Vistas
7 Respuestas
Respuestas (7)
Patchy
Are you still using Mac? most of your posts were in Mac forum.
0 Me gusta
No aplicable
Hm, yes.
I suppose, in my hurry to post, I did not consider that this was a thing Mac would do that Windows could not.
Should I just copy-and-paste it there? —or may we move it?
0 Me gusta
maxim_k
Hi JOSHUA,
The result that you get in PDF is expected as you use in the viewport Visual style other then 2D Wireframe. In this case AutoCAD export viewport contents to PDF as raster image.
The same result you will get in AutoCAD for Windows.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maxim_k
You may try to increase Raster image resolution in AutoCAD PDF printer:
(see attached)
it should be better, but the result still will not be ideal.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Thank you!
Upping both to 4800 pixels must have done something, because now it takes a full 20 seconds to generate the PDF preview. The edges in question, however, are still missing.
Maybe I am going about this wrong. Once I have created a model which I am happy with, and want to share a particular with a client, what is the best way to export? Take a screenshot? Invite them over for tea?
0 Me gusta
pendean
Community Legend
Community Legend
Might be time to post your DWG file for others to try.... .
0 Me gusta
maxim_k
As I wrote before, "the result still will not be ideal". And it is "as designed".
If you need shaded (rendered) high quality view, you may also try to create hi-res rendering here:
https://gallery.autodesk.com/a360rendering
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
