Anuncios
Dimensions
info7MBKQ
Dimensions
info7MBKQ
Hi there,
When I use the rectangle to dimension a room, it doesn't give me the size what I want and when I do offset the same thing. Could you please help me with that?
0 Me gusta
Responder
660 Vistas
13 Respuestas
Respuestas (13)
maxim_k
Welcome to Autodesk Forums!
Hi Morteza,
Can you illustrate somehow the problem?
Do you mean you are drawing a rectangle and its dimensions don't match the distances you want?
Offset of what?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
info7MBKQ
Dimensions.
Hi Maxim,
Thank you for your reply.
Do you mean you are drawing a rectangle and its dimensions don't match the distances you want? Yes.
Offset of what? Offset of walls, door frames and etc.
0 Me gusta
maxim_k
Sorry, but I don't see your answers to my questions. Without them, I can not help you to solve the problem.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
info7MBKQ
Dimensions.
When I'm drawing a rectangle and its dimensions don't match the distances I want.
And when I do offset walls, door frames and etc. don't match either the distances I want.
Thanks.
0 Me gusta
maxim_k
I don't have such issues on my side. How do you enter dimensions for rectangle, when you draw it? The same question about offset. Can you make screen recording?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
info7MBKQ
Please find screen recorded, for dimensions.
0 Me gusta
info7MBKQ
0 Me gusta
maxim_k
You type dimensions for rectangle in wrong format:
when you type "2000,2000" AutoCAD takes this as absolute coordinates and puts the opposite corner of the rectangle at coordinates x = 2000 y = 2000 of current coordinate system.
You should use in this case relative coordinate input and type @Anonymous,2000 when AutoCAD asks for other corner.
Not sure about offset - it should work correctly.
Can you attach drawing with wrong offset results?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
info7MBKQ
Could you please do a screen recording and guide me how can I do the rectangle at coordinates x = 2000 y = 2000 of current coordinate system? Or we can do screen share from TeamViewer!
I think once we solve this problem then offset should works properly.
0 Me gusta
maxim_k
Here it is:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
info7MBKQ
Hi there,
Please watch the video I did a screen record, I would like to type dimensions the same as that not in the command section.
0 Me gusta
maxim_k
Now you show dimension input with Dynamic input turned on.
You can turn on Dynamic input on the Status Bar with this button:
Another way to toggle Dynamic input is with Shifr+Cmd+D shortcut or with F12 (Fn+F12) function key.
As soon as you turn on dynamic input, you can draw rectangle with method you showed in your screen recording -
you will see dimension input in the drawing area.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
info7MBKQ
Hi there,
Thank you so much for your help, the problem is solved.
0 Me gusta
