Anuncios
Dimensions and annotations scale.
UNKNOWN.DESIGN.LAB
UNKNOWN.DESIGN.LAB
Hello Forum,
I must have done something in the settings because my dimensions / blocks are acting strange. Attached are reference images of what happens.
The first image: In model space when i select a dimension its scale enlarges and when deselected it goes back to normal again.
The second image:
If you notice there is a door block in brown that after i change the paper space view port scale to 1:4 for example becomes much larger than it should and dimensions as well become very large. There are several other block in the drawing that do not get enlarged when i change the view port scale and remain the same. Could anyone guide me to what is the setting causing this for this one door block so i can amend it to remain the same scale when i change the view port scale like the others remain the same?
I am sure it has something to do with annotations, which i am still learning about.
Best to all the member of the forum.
0 Me gusta
Responder
Soluciones aceptadas (1)
616 Vistas
2 Respuestas
Respuestas (2)
maxim_k
Solución aceptada
Hi
Looks like your current dimension style is Annotative, if you don't need ut to be Annotative, then go to Dim style properties -> Fit tab -> "Scale for dimension features" -> uncheck "Annotative". To remove annotative property from existing dimensions - select dimension and uncheck "Annotative" in "Annotation scaling" section in Properties palette.
The door block also seems to has annotative property enabled - check this block by opening it in Block Editor and looking in "Block" section in Properties palette.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
UNKNOWN.DESIGN.LAB
@maxim_k to the rescue ! Robot muy feliz
Thank you, appreciated.
0 Me gusta
