AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Defpoints cover my drawing on a mac
6 REPLIES 6
509 Views, 6 Replies
Lately, half way through a drawing, I all of a sudden start getting defpoints which obscure the details within my drawing.
So far, I have not been able to figure out a way to turn them off (get rid of them).
Any ideas?
Thanks, Brent
6 REPLIES 6
Kent1Cooper
Welcome to these Forums!
Can you post an image of what you get?  If it involves crosses and/or X's and/or circles and/or squares surrounding definition-point locations, are you using any custom routines/commands that might be changing the PDMODE System Variable for how Points are Displayed?  Read about that in Help, set it to show just a point, or nothing, and see if that fixes it.  If that's the problem, the code for such a routine/command could be alterable to stop it from doing that.
Kent Cooper, AIA
in reply to: Kent1Cooper
Thank you Kent,
I get grey colored squares that surround the area I am working on.
I will look in help for PD mode.
What surprises me is this has happened before, on occasion, and
always occurs half way through a drawing. I can nor remember changing anything
at the time.
I am off to the help menu.
Brent
imadHabash
Hi and Welcome to AutoDesk Forum,
i suggest to Disable Hardware acceleration from 3Dconfig command.
Imad Habash
Emmsleys
To add you can look to the following help links about POINTS:
If you are still having an issue could you provide a sample file or a few screenshots of your issue?
Thanks.
Sarah Emmsley
Technical Support Specialist
in reply to: Emmsleys
I do believe I have narrowed down my problem.
I might have accidentally turned on my Parametric constraints for the defpoints. Now that I have turned them off, they are not a problem.
Thank you for your time.
Brent
Emmsleys
Thanks for sharing what worked!
Sarah Emmsley
