dashed line in model space not showing paper space autocad LT for mac 2015
No aplicable
dashed lines in plan in model space show as solid in paper space. picked dashed line for object; picked dashed line for that layer; tried everything and just lost work because of it. I hope I have to search and set a hundred line scales in various places to "1" then coordinate several layer items and model space and paper space issues because a 2d drafting program should not be simple! I forget this is "robust" program haha :cara_con_una_leve_sonrisa:
Responder
Soluciones aceptadas (1)
14.723 Vistas
4 Respuestas
Respuestas (4)
maxim_k
Solución aceptada
Welcome to Autodesk Forums!
Try to use LINETYPE command to open Linetype Manager dialog (Menu: Format ➤ Linetype) and while you are in Layout uncheck "Use Paper Space Units for Scaling". Close dialog to save changes, use REGENALL command to regenerate all viewport.
You need to repeat steps above for all Layouts in the drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Thanks it worked. Can I get a manual that has this stuff in it? (Autocad LT for Mac)
0 Me gusta
maxim_k
Unfortunately there is no special reference manual for AutoCAD LT 2015 for Mac, but for general reference you can use any of the manuals about AutoCAD LT (PC version) keeping in mind differences between PC and Mac versions:
http://www.autodesk.com/products/autocad-lt/compare/compare-platforms
You can also try this video course:
http://www.infiniteskills.com/training/learning-autodesk-autocad-lt-2015-for-mac.html
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Thank you.
0 Me gusta
