Anuncios
CUSTOM MLEADER ARROW DISAPPEARS
bret_wieseler
bret_wieseler
I'm trying to create an mleader with a custom "arrowhead".  I can add the arrowhead to the leader with no problem, but I have to drag it so far away from the reference tag.  If I move it any closer, the arrowhead disappears.  Is there something I can do to alleviate this issue?
Thanks.
iMac | 3.6 GHz 8-Core Intel Core i9 | 64 GB | Ventura 13.6.6 | Autocad LT for Mac - 2024.1.2
0 Me gusta
Responder
Soluciones aceptadas (1)
421 Vistas
7 Respuestas
Respuestas (7)
maxim_k
Hi @bret_wieseler ,
Can you share drawing with mleader with this custom arrowhead?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
bret_wieseler
Maxim,
I've attached the file you requested.
Thanks.
0 Me gusta
pendean
Community Legend
Community Legend
Greeting @bret_wieseler
May I ask why you need this long line in your custom arrow block? That's the problem
Looks like you created the problem to solve a problem with your arrow's placement having a gap perhaps?
It appears you want this all to be annotative too, is that correct?
0 Me gusta
bret_wieseler
Pendean,
If I don't draw that line, there is a gap between the arrowhead and the mleader.  It seems like all the arrowheads that AutoCAD provide have a stem of sorts.  See below:
0 Me gusta
pendean
Community Legend
Community Legend
You are correct in your observations @bret_wieseler
EDIT: Your line's length is the problem, here they all are side by side at 1:1 scale. That's it in your posted file, I'm not sure what your screenshot is from, your custom block's size is out of whack
0 Me gusta
maxim_k
Solución aceptada
Hi Bret,
 @bret_wieseler
This is "by design" - AutoCAD hides multileader arrowhead when the first leading segment is less than twice the length of the arrowhead.
But there is a workaround.
Please look at the attached DWG - try multileader inside yellow rectangle.
Does it work for you?
If yes, then idea of the workaround is to make block elements four times bigger then it should - in your case I scaled objects inside arrowhead block 4 times.
Now you need to edit multileader style and set the scale of the arrow to 1/4:
 That is all.
The new multileader style in your drawing is MLDR-REFR-DETL-1 and arrowhead block for it is REFR-ARRW-1.
All kudos should go here:
https://forums.autodesk.com/t5/autocad-forum/multileaders-disappear-with-a-short-leader/m-p/8050222#...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
bret_wieseler
That makes sense.  Thanks again Maxim!
0 Me gusta
