Cursor Disappears when moving to Select a Command over Menu Area
LauraLis
LauraLis
VIDEO ATTACHED... I grab an item to copy - then go to select COPY command, but the cursor DISAPPEARS... It's there, but I CANNOT see it.
During that, if I click, it selects some other command over which it happens to be located.
It's nerve racking! How is that even possible after decades of CAD... I use iMac ... PLEASE HELP! THANK YOU!
0 Me gusta
Responder
Soluciones aceptadas (1)
1.056 Vistas
12 Respuestas
Respuestas (12)
VincentSheehan
Could it be a graphics issue? Have you tried updating the drivers. I know MAC is a little different on updates.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
0 Me gusta
LauraLis
iMac desktop computer comes with whatever it comes with, I would not know how to update it.
0 Me gusta
pendean
Community Legend
Community Legend
What is your exact AutoCAD for MAC year version?
And what is your MacOS version?
0 Me gusta
LauraLis
I use Autodesk Subscription, and update to latest version as soon as it comes out.
Mac OC Sonoma, and no updates are due as well. Version 14.2.1 (23C71)
The cursor decides to show up our not at random... I've been just dealing with it, hovering and clicking around, but it slows down work tremendourly.
0 Me gusta
ChristopherHoy3923
Ant resolution to this?  I am having the same issue.  Super frustrating!
Autocad for Mac 2024
Macbook Pro
M2 Max Chip
64 GB memory
macOS Sonoma 14.3.1
ChristopherHoy3923
Any resolution to this?  I am having the same issue.  Super frustrating!
Macbook Pro
M2 Max Chip
64 GB memory
macOS Sonoma 14.3.
0 Me gusta
maxim_k
Solución aceptada
Hi @LauraLis and @ChristopherHoy3923 ,
Have you installed 2024.1.1 Hotfix for your AutoCAD?
This Hotfixh should fix this problem:
"Fixed Issues
macOS Sonoma Compatibility
- AutoCAD for Mac now maintains consistent performance even after extended usage in macOS Sonoma.
- Cursor moving on grips no longer triggers a selection window in macOS Sonoma.
- Tooltips on the toolbar and toolset panel now show correctly in macOS Sonoma.
- Cursor no longer disappears when moving in the drawing area with a displayed shortcut menu in macOS Sonoma.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
LauraLis
I used to work on MacBook Pro... but now the battery is dead. One person suggested to Install Hotfix update, hope it works.
0 Me gusta
LauraLis
Thank you, I will try installing this!
0 Me gusta
LauraLis
So far I cannot find the actual HOTFIX plug in...is it a separate program all together?
I installed a new version of CAD, hope that solves it.
0 Me gusta
maxim_k
Hi @LauraLis ,
You can use "Check for Updates" from menu AutoCAD - you need to allow Notifications  for AutoCAD in macOS System Settings:
Or you can download Hotfix from your Autodesk account.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ChristopherHoy3923
Maxim,
I installed the hot fix but still experience the same issue.  When dragging the cursor across the screen it freezes at the edge of the tool or properties bars and the arrow disappears as well.  Sometimes it shows up  and sometimes not.  If you ESC it usually comes back but seems to still be buggy.
0 Me gusta
