Anuncios
Creating layouts larger than printer
No aplicable
I have installed Autocad 2017 for Mac (trial) and I would like to create a A1 layout, however the only printer connected to my Mac is a A4 printer.
Is it possible to add a driver without actually having the printer, so that Autocad allows me to create a larger layout? Assuming that's the reason why layouts won't go lager than A4 despite the page setup listing it as A1.
I have tried a few large format drivers, but they won't work without connecting the printer!
0 Me gusta
Responder
304 Vistas
3 Respuestas
Respuestas (3)
maxim_k
Hi Nathan,
You just need to create Custom paper size and assign it to layout:
http://autodesk.blogs.com/between_the_lines/2011/01/quick-tutorial-plotting-custom-paper-sizes-in-au...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
john.vellek
Hi @Anonymous,
Maxim's advice to create a custom sheet size works well. I do have a large format plotter driver installed on my Mac though so I can select through its paper sizes when plotting.  To install a driver when the device doesn't exist, you might have to provide a dummy IP address. Which driver are you trying to install?
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
I am checking back to see if my post or Maxim's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
0 Me gusta
