Counting blocks in blocks
No aplicable
Is it possible to easily count blocks in a drawing, i havent needed to for a long time and used to be able to extract to a table in 2007 version. Now on a MAC and struggling to work out an easy way of doing this.
Hope someone can help, all i need is names and numbers!
0 Me gusta
Responder
Soluciones aceptadas (2)
590 Vistas
4 Respuestas
Respuestas (4)
maxim_k
Welcome to Autodesk Forums!
If you are using full AutoCAD, you can try this AutoLISP routine:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Count-lsp-modifications/m-p/1996864#M...
It should work in AutoCAD for Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Thanks Maxim,
I am using the LT version, but i will have a look at this solution.
Regards
Tim
0 Me gusta
maxim_k
Solución aceptada
As AutoLISP is not available in LT, the only one quick solution is to use QuickSelect to find all blocks in the drawing with particular name. Than you will see the quantity of the blocks in the drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Emmsleys
Solución aceptada
To add you can also add your feedback about the product here: http://www.autodesk.com/company/contact-us/product-feedback
Maxim also made a suggestions here you could try: http://forums.autodesk.com/t5/autocad-for-mac-forum/counting-blocks/td-p/3882933
Sarah Emmsley
Technical Support Specialist
