Anuncios
Converting to pdf lines come out dark until zoomed in
hsmpycoc
hsmpycoc
image.jpgimage.jpgWhen I convert my cad file to pdf the lines are very dark until I zoom in and the lines become back normal and thin again, why is this happening?
0 Me gusta
Responder
370 Vistas
11 Respuestas
Respuestas (11)
pendean
Community Legend
Community Legend
That's a PDF viewer display setting change you need to make on your end, it has nothing to do with AutoCAD sadly.
0 Me gusta
hsmpycoc
What setting is it, how would I change it?
0 Me gusta
pendean
Community Legend
Community Legend
@hsmpycoc  Go into your PDF viewer's PREFERENCES section, PAGE DISPLAY or DISPLAY section, and explore. I use these setting for example but your experiences may be different
0 Me gusta
maxim_k
Hi @hsmpycoc ,
You use Power Point and insert PDF produced by AutoCAD to a slide.
I'm afraid there is no special settings for PDF resolution / quality.
Can you share one of PDF files you are trying to insert to Power Point presentation?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
hsmpycoc
here is the pdf file
0 Me gusta
maxim_k
@hsmpycoc ,
I cannot say that your PDF is very dark on my Mac when I insert it into PowerPoint (the same zoom level as in your screenshot):
And I have a question:
Do you have Acrobat connected somehow to PowerPoint?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
pendean
Community Legend
Community Legend
@hsmpycoc this is your PDF on my screen in Adobe Acrobat Reader
and in PowerPoint
I'm not sure your display issue is PDF related either: but... how did you include the PDF in your PowerPoint page?
0 Me gusta
hsmpycoc
I changed the colours on the cad file so it isn't so much the darkness. When you zoom in on the powerpoint the lines become thinner (as they should be) whereas just looking at it on the page the lines are very close and look thicker than they should
0 Me gusta
hsmpycoc
yes it shows up fine in my adobe acrobat too its just when I insert it into powerpoint, I went onto insert then image and then picture from file, is this what you have done to?
0 Me gusta
pendean
Community Legend
Community Legend
Ah, you took a snapshot of the PDF: try this instead https://pdf.wondershare.com/powerpoint/insert-pdf-into-ppt.html#:~:text=Method%202%3A%20How%20to%20I...
0 Me gusta
hsmpycoc
I have done some reading up and unfortunately there's no way to insert a pdf into powerpoint on a MacBook, which will be the reason, thank you anyway!
0 Me gusta
