Converting Polyline ARC segment to multiple LINE segments
earthsquare
Message 1 of 22
earthsquare
Hi.
Is there an option to convert, polyline ARC segment to multiple LINE segmnets.
The decurve option, converts the arc into single line.
Regards
Sreejith.S
Landscape Architect
Replies (21)
Message 2 of 22
pendean
Community Legend
Community Legend
Nothing built in to do that if I understood your need correctly (my guess is you need a curved tile edge?).
Can you use POLYGON command to create a circle with line segments at a matching radius, then EXPLODE and replace the ARC?
Message 3 of 22
maxim_k
Hi Sreejith,
As @pendean mentioned, there is no build-in functionality for converting polyline arc segments to series of straight lines, but I believe you can use AutoLISP routine to accomplish this.
I have found one (see attached), but it works only with old-style "heavy" polylines, so before using it you need to convert "light" polyline to "heavy" with CONVERTPOLY (undocumented) command:
https://www.cadforum.cz/cadforum_en/command.asp?cmd=convertpoly
Then APPLOAD attached LSP file and use PLXL command, which has "Deflection angle" option which allows you to control number of line segments by changing "Deflection angle" - the greater is this value, the more segments will be created.
After using the routine you can convert "heavy" polyline back to "light" with CONVERTPOLY command
Here you can read more about "heavy" and "light" (Lightweight) polylines.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 22
earthsquare
I was trying to use wipeout command. It unfortunately recognises only polylines with line segments and not arc segments. The workaround is to manually draw multiple polyline, line segments around the curve. The problem is that it is not perfect Smiley Sad as the original block.
Regards
Sreejith.S
Sreejith.S
Landscape Architect
Message 5 of 22
earthsquare
Hi Maxim,
Hope you are doing great.
Thanks for the tips. let me try it and get back to you.
People like you, make AutoCAD a better space to work with.
Regards
Sreejith.S
Landscape Architect
Message 6 of 22
maxim_k
Here is another way, without using AutoLISP.
The limitation of this method is that you can use it with closed polylines.
- Draw polyline with arc and line segments, ensure it is closed
- Use SUPERHATCH command with Wipeout option and create wipeout by picking point inside closed polyline
- move resulting wipeout to empty space in order to be able to work with it freely
- use EXPLODE command to explode wipeout to lines
- use JOIN command to join lines to new polyline.
You can control number of lines which approximate arc segments with SUPERHATCHTOLERANCE system variable (default value is 0.01)
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 22
earthsquare
Hi.
I work on AutoCADLT for Mac 2020. I think APPLOAD and PLXL doesn't work.
regards
Sreejith.S
Landscape Architect
Message 8 of 22
maxim_k
OK. then try:
https://forums.autodesk.com/t5/autocad-for-mac-forum/converting-polyline-arc-segment-to-multiple-lin...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 22
earthsquare
Thank you.
It worked.
Smiley Happy
Sreejith.S
Landscape Architect
Message 10 of 22
c.haynes-BM
Hi does anyone know how to do the opposite of this?
I wish to convert Polylines made up of multiple LINE segments to Polylines with ARC segments with the least amount of nodes as possible
Message 11 of 22
maxim_k
Hi Chris,
Try PEDIT command with Fit (or Spline) option:
http://help.autodesk.com/view/ACDMAC/2018/ENU/?guid=GUID-648BDC21-E835-478F-A318-9D201479998D
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 22
JaysonE
Easiest way I have found is to:
1. create a dummy surface around your polyline. (you can do this with break lines)
2. create an outer boundary to your polyline.
3. set the mid-ordinate distance to a very low number. (like 0.1')
This will create a polyline with segments without arcs.
Message 13 of 22
tomislav_vargek
Hello.
So, I edited original PLXL.lsp so now it takes LWpolylines also, if anyone needs it.
Message 14 of 22
I really appreciate it, but I thinks there's a bug in the code. 😞
Message 15 of 22
pendean
Community Legend
Community Legend
@Anonymous How doe it fail for you? Please elaborate.
Message 16 of 22
gramosC4MGW
Convert the 2D Polyline to a 3D Polyline.  Then convert it back to a 2D Polyline.  It should create small line segments along the arcs so you can use that polyline for wipeouts.
Message 17 of 22
julie.walker2
very neat solution, thanks! (pendean's polygon solution) didn't even need to explode, just used the polygon for the wipeout.
Command: Polygon
choose number of sides
select center point
select edge of circle
Inscribe IN because I wanted wipeout to be within the circle
boom, polyline.
Command: wipeout, polyline, select polyline, no for erase polyline
Move to back, and I made my circle and the wipeout a group because it's in a block and I get unpredictable results when I import the block, with the wipeout trying to move to the front, but I don't know if that's the best way to accomplish that. If anyone has an solution for that I'm all ears
This is my work ID, since now your ID is associated with your software.
My other ID is Julesagainn.
AutoCAD user since 1988.
Message 18 of 22
drafting605
You're awesome! This made my life so much easier!
Message 19 of 22
ceinig
Converting 2D Poly to 3D poly was the solution I was looking for.
Message 20 of 22
r_baccioni
Convert poliline using wmfout, then import the wmf back using wmfin. Explode the block and join.
