Anuncios
Compatibility with MacOS Sonoma
hugotron
hugotron
Hello. I wanted to know if AutoCAD/AutoCAD LT for Mac are already compatible with next week MacOS Sonoma release, or if there is an update in progress.
Thanks!
0 Me gusta
Responder
Soluciones aceptadas (1)
2.179 Vistas
18 Respuestas
Respuestas (18)
maxim_k
Hi @hugotron ,
All current AutoCAD for Mac / AutoCAD LT for Mac versions (2021, 2022, 2023 and 2024) are not officially supported on upcoming macOS Sonoma.
You'll need to wait for new Updates before moving to Sonoma.
According to Autodesk policy, Updates must come for the latest three versions of AutoCAD for Mac - 2022, 2023 and 2024.
I believe the Updates will be released just before or shortly after Sonoma's release.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Solución aceptada
Hi @hugotron ,
AutoCAD for Mac 2024 received 2024.1 Update, which fixes compatibility issues with macOS 14 Sonoma and improves user experience and overall stability of the product.
If you wish to upgrade to macOS Sonoma and want to use AutoCAD for Mac, you need to install this Update at first.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
hugotron
Thank you for the info Maxim!
Great support form Autodesk :símbolo_para_indicar_que_todo_está_en_orden:!
I’ll give it a try.
ireneAZESA
Does this apply to AutoCad LT for Mac as well?
0 Me gusta
maxim_k
Hi @ireneAZESA ,
The information about AutoCAD LT 2024 for Mac 2024.1 Update is here:
https://help.autodesk.com/view/ACDLTM/2024/ENU/?guid=AUTOCADLT_MAC_2024_1_FIXED_ISSUES
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
hugotron
Hello. I am in LT and it works with no problems. I’m not a power user anyway. But smooth experience.
JEFFJW9BB
I have AutoCAD LT for Mac and when I go to the download page it says none are available.  I'm confused.  See clip attached
Jeff
0 Me gusta
ireneAZESA
I found it on my page and downloaded and it worked.
0 Me gusta
JEFFJW9BB
This link is the notes for the update but I do not see where the actual update is. I do not know where to look. Please excuse my blindness but any help would be appreciated.
Jeff
0 Me gusta
JEFFJW9BB
Thank you for your reply but where exactly on that page should I look for it? I attach a pdf of the page.  I very much appreciate you pointing me to it.
Jeff
0 Me gusta
pendean
Community Legend
Community Legend
Jeff
Looks like it got pulled by Autodesk. You'll have to wait for a repost from them, it might not be good to use if you find it anywhere else for now anyway.
0 Me gusta
maxim_k
Hi Jeff,
@JEFFJW9BB
It is strange, but I also don't see Update if I open "View details" under "All Products and Services" -> "AutoCAD for Mac".
Try to select "Product Updates" on the left side - I can see this Update there:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maxim_k
@JEFFJW9BB
You can also use "Check for Updates" from "AutoCAD LT" menu - please check that you enable "bubble" notifications for AutoCAD in macOS System settings before checking Updates inside AutoCAD.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ireneAZESA
I have notifications turned on but it never shows the updates inside
autocad.
0 Me gusta
maxim_k
autocad.
The Alerts should be selected I notifications settings:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
JEFFJW9BB
Thank you very much!
0 Me gusta
JEFFJW9BB
Worked like a charm. One must have this turned on.
0 Me gusta
JEFFJW9BB
Very true! you must actually click that box on the right.  It is not clear because they all look turned on.
Many thanks (again)!
0 Me gusta
