Compatibility new MacBook M1 chip
Message 1 of 78
Does anyone have any information on whether the new M1 chip MacBooks will get support?
Replies (77)
Message 21 of 78
  • Any update on the compatibility of m1?
Message 22 of 78
It’s compatible, as mentioned in this thread, with update
Message 23 of 78
PaulMarsh8527
Just loaded the free unregistered copy of Autodesk LT on a M1 2020 Mac Mini and yes it has the graphics problem.
Have updated the Mac to the latest version which installed Big Sur 11.1 but no good graphics are looking crap.
What is the 2021.1 version? If i'm not mistaken this free version is 2021.2 ?
Is there a version that operates under Rosetta 2 mode, which as I understand automatically operates the program to intel based operation.
Message 24 of 78
k.mozuraitis
Hello PaulMarsh8527,
Do not forget to do couple things, as mentioned before in this topic.
1. Change graphic settings to Open GL
2. Update the AutoCAD to latest version.
Message 25 of 78
PaulMarsh8527
Yes have got it to work, and the trick ... restart after making the changes. Cheers😀
Message 26 of 78
jjid1
Observer
Observer
Purchased Mac Pro 13" with M1 Chip.  Autodesk spent over an hour on my computer trying to do a work around to get it to run AutoCAD for mac 2021.  They downloaded Rosetta 2-changed some of the code.  Program would not run.  I waited 6 weeks to build the MAC and now have to return.  Does anyone have any further information on this incompatibility issue ?
Message 27 of 78
I am facing the exact same issue. Have you managed to resolve it?Screenshot 2021-02-04 at 1.40.46 PM.png
Message 28 of 78
maxim_k
Welcome to Autodesk Forums!
Hi @Anonymous,
What AutoCAD version do you use and what Mac model do you have.
If you are using AC 2021 on a Mac with M1 chip, then you just need to install the last update - AutoCAD for Mac 2021.1.1 HotFix. Use "Check for updates" from autoCAD menu.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 29 of 78
Do you guys have a optimized version of an a my Autocad for m1? If not I hope you do before next winter I need your program for school the m1 chip is very fast and smooth I’d be excited to use the program on my new Mac book
thank you
Message 30 of 78
Hello. Is it working only on Autocad or is it all Autodesk software; Revit, Sketchbook Pro, Bim 360, Maya, Fusion etc.
Message 31 of 78
p_r0gers
Community Visitor
Community Visitor
That's great news.
Do you have any idea on timescales for when this may get rolled out?
Message 32 of 78
Did you find a solution to it?
Message 33 of 78
k.mozuraitis
You should read the topic with more attention.
The solution was written above.
Message 34 of 78
I am facing the same issue. Were you able to get any resolution of the above?
Message 35 of 78
woods_j
Observer
Observer
I guess it is the luck of the draw on this one – my system appears to be running fine on the latest version even with the metal engine enabled yet others appear to be having a nightmare. Until they have a universal binary available there may be issues for anyone running it and probably best to stick to Intel if it is an important part of your workflow.
Message 36 of 78
the trick seems to work, thanks!
Message 37 of 78
thanks!
Message 38 of 78
Same issue here. I am wondering if this has been fixed?
Message 39 of 78
maxim_k
Hi @Anonymous
Yes, install this update:
For AutoCAD LT 2021 for Mac - AutoCAD LT for Mac 2021.1.1 Hotfix
For AutoCAD 2021 for Mac - AutoCAD for Mac 2021.1.1 Hotfix
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 40 of 78
Thank you for your help. Much appreciated.
