Community Discussion – AutoCAD
daniel.Alvarado.cortes
Hello AutoCAD Users,
Want to be consistent when building objects on AutoCAD? I found a great resource to help guide to the right path on building objects. :cara_que_sonríe_con_ojos_sonrientes:
I am sharing the article to discuss: Creating Blocks in AutoCAD for a Mac
To participate in the discussion:
  • Write your comments, thoughts, and questions and feel free to agree or disagree with the ideas presented in the article. I would like to hear all kinds of feedback :cara_que_sonríe_con_ojos_sonrientes:
Discussion Questions:
  1. What kind of objects to you create using AutoCAD?
  1. Were the resources provided helpful? If so, why?
We invite anyone to participate in these discussions and look forward to the conversations!
0 Me gusta
Responder
389 Vistas
2 Respuestas
Respuestas (2)
Alfred.NESWADBA
at first, I guess good videos for starters, I would miss some essentials like how to enter coordinates, using object snap, ... before going into edit blocks. But as always, the order which ones first ... as well as hold them attractive ... keep the user watching instead of getting them bored ... not easy :cara_guiñando_un_ojo:
Video 1 ... About Blocks:
Statement in text above the video:
>> Because blocks are locked, instances of blocks are
>> always consistent across projects.
My opinion:
Not true, as I define "projects" as a set of drawings, but a block "TABLE" in a drawing A can be different to a block "TABLE" in drawing B, so the wording "consistent across projects" is not guaranteed.
Also "locked" sounds for me like "not changeable" ... you can modify blocks, you can replace blocks (same name, other content), so "locked" (for my limited English language skills) sounds incorrect.
Statement in the video (at about 1:00):
>> Blocks can not be accidentally stretched
True, but the bad sample in the video is that you have dynamic blocks selected at that time ... and the selected blocks have stretch parameters, a bit irritating :cara_guiñando_un_ojo:
Video 2 ... Creating Layers:
That's not really incorrect, but from the practice side of CAD ... in most cases you start a hole with the centerline :cara_guiñando_un_ojo:
Also not that beautiful: the dense of hidden linetype does not fit to the dense of the center linetype. In your sample the hidden should have a bigger ltscale.
Video 5 ... Update Blocks:
Statement above video:
>> Use the Insert Block dialog box to insert the block in the DWG file into a drawing.
My opinion:
"the block in the dwg-file" is not correct, as in the file L-DESK.DWG does not have "a block in the dwg-file".
Should be something like "insert the dwg as block into another drawing"
Just my 2c, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
RobDraw
Them are some rookie mistakes. The topper is "AutoCAD for Mac" being posted in this forum for the Windows version.
Rob
