Anuncios
Command Tilde Short Cut
No aplicable
I have recently upgraded to AutoCAD 2017 from AutoCAD LT 2015. In 2015 if I used the shortcut: Command Tilde, to easily switch between the different autoCAD files I had open (This same shortcut works for most other programs on my computer such as Photoshop, Acrobat, Illustrator) However 2017 doesn't have this same shortcut. Does anyone know of a similar short cut or a way edit the shortcuts to include this?
Thank you for your help.
0 Me gusta
Responder
1.564 Vistas
3 Respuestas
Respuestas (3)
maxim_k
Welcome to Autodesk Forums!
In 2017 version you can switch between File Tabs (opened drawings) with Control+Tab shortcut.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Thank you for your response.
Control Tab Switches between all files open on my computer (including mail or photoshop etc.) and requires opening each CAD file as if its a new program.
Is there a way to switch between the tabs (Image below)
0 Me gusta
maxim_k
It is Ctrl+Tab - I'm sure.
Command+Tab - switches between applications on Mac (Application switcher)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
