command DATAEXTRACTION
Buenos días
soy nuevo en el forum. Acabo de instalar una versión para estudiantes del Autocad 2018 para Mac y estoy intentando usar el comando DATAEXTRACTION pero el programa no lo entiende y devuelve el dato "Unknow command". Hay que instalar previamente alguna rutina? O es que la versión para estudiantes no es completa de todos los comandos?
Gracias
maxim_k
Welcome to Autodesk Forums!
Hi Matteo,
Data Extraction wizard is not available in AutoCAD for Mac.
On Mac you can use -ATTEXT command (yes, with dash) to extract attributes:
https://help.autodesk.com/view/ACDMAC/2018/ENU/index.html?guid=GUID-EF25B7C4-5C5E-4AA2-89E1-227ADAD3...
Here you can find a post, that includes a Screencast on how to go through the process of data extraction:
https://forums.autodesk.com/t5/autocad-for-mac-forum/how-do-i-use-data-attribute-extraction-on-autoc...
And here you can find another quick video tutorial:
https://www.youtube.com/watch?v=j6wbR8WBYYw
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ChrisPreece
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD for Mac forum.
I'm just checking in to see if you need more help with this. Did the suggestion that @maxim_k provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris Preece
Technical Support Specialist
