Circle is a Polygon on 3D Model
I've been drawing the attached image and I'm getting issues with what should be circles being shown as polygons. I've tried the following commands without success: REGEN, FACETRES and VIEWRES. I expected it to be redered properly when exported to a PDF however it's still a polygon.
Any help would be much appreciated.
maxim_k
Welcome to Autodesk Forums!
Hi Steve,
Is the model in the drawing 3D Solid?
Can you attach the drawing itself?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thanks for the quick reply. If my definition of '3D Solid' is correct, then yes it is. I've added the drawing.
maxim_k
Your model is too small, if you scale it up, for example, 100 times you will see the difference.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Is that to say there's nothing to be done? Doesn't seem right that even when exporting to a PDF it still displays a polygon.
