Anuncios
Changing page size in layout causes Autocad LT 2017 to crash
No aplicable
Has anyone else encountered or figured out a solution to this issue?:
Files work just fine until:  I change page size for a layout.  The change happens correctly.  The edit window closes, and I can see the new page size format in layout.  A second later I get the rainbow pinwheel and the pop up that says autocad needs to quit.
This impacts every file I have as well as newly created files.  This is my first attempt to edit layout page sizes in 2017.
I'm running Sierra and did not have this problem with LT 2016.  I'm on a new machine and license now, which I why I switched to 2017, so going back to 2016 doesn't come up for me as an easy option (I think).
Any help or insight would be greatly appreciated!
Scott
Responder
489 Vistas
2 Respuestas
Respuestas (2)
Emmsleys
@Anonymous,
I seen that no one responded your thread so I wanted to do a follow up.
Were you able to find a work around that helped?
To add you could try applying any updates for your Mac and AutoCAD 2017, or have you already done so and continue to get crash issues?
Sarah Emmsley
Technical Support Specialist
0 Me gusta
maxim_k
Hi Scott,
If you are using AutoCAD on new Macbook Pro with Touchbar, than please look here :
http://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-issues-on-the-new-macbook-pro-with-touch...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
