- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I'm having some trouble about changing the layer of a block. I'm loading the block here. Can you help me please?
¡Resuelto! Ir a solución.
I want it to be on a separate layer actually I just wanted to change its line weight to 0.09mm.
What is dynamic block? and im using AutoCAD 2016.
Dynamic Block Explained https://www.youtube.com/watch?v=A9RZBHnlJD4
Block Editor is the best way to do what you want https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/CloudHelp/cloudhelp/2016/E...
and
What exactly is the trouble you are having?
Hi Gizem,
Edit the block in Block Editor - change Layer of all objects inside the block to layer "0", save changes.
Now if you will insert the block to the Layer with Lineweight property set to 0.09 - the block elements will take 0/09 lineweight.
See attached drawing.
Maxim
