cannot import CTB
cannot import CTB
No aplicable
HI,
Here are the screenshots.
When I click the CTB file, it pops up a window showing that I can save the plot.
But it doesn't seem working.
So, I went to option>application, and then click "+".
Somehow I can't select on my CTB file.
please help me I am feeling desperate.
0 Me gusta
Responder
Soluciones aceptadas (1)
1.502 Vistas
4 Respuestas
Respuestas (4)
maxim_k
Solución aceptada
Welcome to Autodesk Forums!
When you add custom folder for plot style table search path you need to select the folder where your custom CTB file is located, but not the file itself.
So you need to select "Clearspace" folder to add it to plot style table search path.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Thank you for replying, the CTB file is successfully imported!
However, the layer setting in the CTB file doesn't show up on the properties inspector window.
Thank you a lot!!!
0 Me gusta
maxim_k
These settings should not appear there (in Properties palette), they are only visible in the Plot Style editor because they are only for printing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
john.vellek
Hi @Anonymous,
I am checking to see if maxim_k solved your CTB issue. If so, please mark his post as an a Solution so others might benefit.
John Vellek
0 Me gusta
