Cannot draw with dimension in feet
seyie
Observer
seyie
Observer
Observer
I recently (in the last few weeks) started having trouble drawing any line or shapes (circle, rectangle) by typing the dimension in "feet."  It still allows me to draw with dimensions in inches.  This was not a problem before.
Could you please help me resolve this as it is not convenient to work otherwise.
Thanks!
0 Me gusta
Responder
Soluciones aceptadas (2)
556 Vistas
4 Respuestas
Respuestas (4)
Emmsleys
Hi @seyie
I'd like to get a bit more information from you if possible;
  • What AutoCAD release are you working in?
  • Have you applied all updates (if applicable) ?
  • What version of MAC OS are you running?
  • Does this happen with all files or only specific few?
You could try;
  • Logging in as a different user on your system. Open AutoCAD and see if the issue still occurs in that environment.
Let me know if you have any questions for me.
Sarah Emmsley
Technical Support Specialist
0 Me gusta
maxim_k
Solución aceptada
Have you tried to set current units to Architectural or Engineering using menu Format -> Units?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Emmsleys
Hi @seyie
Just following up to see if you need additional support on your thread or if you resolved the problem post back when you can and let us know.
Thanks.
Sarah Emmsley
0 Me gusta
Emmsleys
Solución aceptada
To add to this thread;
You can also look to the following links for help on changing or specifying which units of measure you are in.
Or if that does not work I would suggest resetting your settings to default and then testing your files once more.
Sarah Emmsley
0 Me gusta
