Anuncios
Can't switch between layers
No aplicable
I can't seem to switch between layers. It keep staying on the same layer and when I try to PDF, although I will see the plans on Layout, I won't see it on the PDF after printing.
I hope I explained myself right.
Thanks!
0 Me gusta
Responder
414 Vistas
2 Respuestas
Respuestas (2)
maxim_k
Welcome to Autodesk Forums!
>>>I can't seen to switch between layers.
What do you mean:
- you cannot change objects layer?
- you cannot change current layer?
please verify that the layer you cannot see in PDF is not set as "not to print" in the Layers palette.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Pothman
Are you still having a problem with layers? If so can you explain in more detail as to what is happening? Also a video showing what is happening can really help. You can download a free video recorder from Autodesk here:
www.autodesk.com/screencast
Dave Pothier
0 Me gusta
