Can't Print or save to PDF.
I recently install Autocad Mac Lt 2020 and I can't print or save to PDF. I already erased and reinstall all my printers with the latests drivers. I can't even see a preview of the print. I using a MacBook Pro  14,3 running Catalina 10.15.4 Beta.
Sugestions?
Replies (7)
pendean
Community Legend
Community Legend
Beta OS are usually problematic and is most likely the root cause of your issue.
But there is a 2020 update you need to install regardless, go get it and see if it helps.
maxim_k
Hi Renato,
In order to save to PDF from AutoCAD you don't need any printers installed in "Printers & Scanners" pane of macOS System Preferences.
Are you able to save to PDF with standard "AutoCAD PDF" printers?
Have you installed latest update for AC LT 2020 for Mac? Here is the link to the Update:
https://knowledge.autodesk.com/support/autocad-lt-for-mac/downloads/caas/downloads/content/autocad-l...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
dreuillesromain
Community Visitor
Community Visitor
Same problem for 4 days...
Any issue?
maxim_k
Welcome to Autodesk Forums!
Hi
Are you able to use standard "AutoCAD PDF" printers to save to PDF?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
dreuillesromain
Community Visitor
Community Visitor
Hi!
No, impossible to print with any printer (pdf or not).
It makes AutoCad crash.
The problem appeared since my MacBook Pro installed the 10.15.4 version.
maxim_k
10.15.4 is in Beta stage. AutoCAD is not supported on Beta versions of macOS.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
Community Legend
Community Legend
@maxim_k That's what I said too 🙂
