Can't open or install the software on MacOS 12.3Beta
1831260872
Community Visitor
1831260872
Community Visitor
Community Visitor
The software can't be opened, I tried to reinstall, but the program got zero response, I've tried different versions, all came out the same circumstance.
maxim_k
Welcome to Autodesk Forums!
Hi @1831260872 ,
AutoCD for Mac is not officially supported on Beta versions of macOS.
Maybe there is some bug in macOS 12.3 Beta, which prevents AutoCAD Installer to run correctly.
BTW, have you tried to restart your Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
t_shanr
We have seen a lot of users lately who either, are not able to proceed post "preparing for installation" phase or are not able to run the installer as it gets stuck at "not responding", here is what you can do and that would help.
First run the following commands in terminal :
Note : Run them one by one, commands which start with the word sudo will need you to enter your mac
login password, you will have to type it and press return/enter on keyboard, catch is that you will not
be able to see the password being typed, that's how apple set it up.
One last thing, some commands may return error- permission denied, add sudo and space before those commands and
then run them, that will work.
rm -rf /Library/Application\ Support/Autodesk/AdODIS rm -rf /Library/Application\ Support/Autodesk/DDA rm -rf /Library/Application\ Support/Autodesk/ODIS rm -rf $HOME/Library/Logs/Autodesk rm -rf $HOME/Library/Logs/Autodesk\ Installer rm -rf $HOME/Library/Application\ Support/AutodeskInstaller sudo launchctl unload /Library/LaunchDaemons/com.autodesk.AdskLicensingService.plist pkgutil --forget com.autodesk.AdskLicensing rm /Library/LaunchDaemons/com.autodesk.AdskLicensingService.plist killall AdskLicensingService rm -rf /Library/Application\ Support/Autodesk/AdskLicensing rm -rf /Library/Application\ Support/Autodesk/AdskLicensingService rm -rf /Library/Application\ Support/FLEXnet\ Publisher rm -rf /Library/Frameworks/Adlm.framework rm -rf $HOME/Adlm rm -rf $HOME/Library/Application\ Support/Autodesk sudo chmod -R uga+rw /Library/Application\ Support/Autodesk/AdskLicensingService launchctl load /Library/LaunchDaemons/com.autodesk.AdskLicensingService.plist
Once done go to the finder then browse to ~/library/preferences via go to folder option on the mac top bar (Go > go to folder)
Once in that folder delete any com.autodesk.... files you see, once done
browse to /library/LaunchDaemons and delete any left over files from autodesk and the restart and try installing the application, it will work.
I know its a little lengthy and complicated but it will work for sure, do let me know if you have additional questions and in case you want someone else to do it for you, contact Autodesk support 🙂
