AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Can't draw a rectangle with dimensions!
20 REPLIES 20
Message 1 of 21
info7MBKQ
3717 Views, 20 Replies
Hi There,
Please find attached you can see when I drawing lines I'm able to type the dimensions but when drawing a rectangle then can't type dimensions. Please guild me how to sort out this issue.
20 REPLIES 20
Message 2 of 21
maxim_k
in reply to: info7MBKQ
Hi @info7MBKQ
Please verify that you have "Enable dimension input ..." option checked on Dynamic Input tab of drafting settings:
 If this won't help, try these steps:
- relaunch AutoCAD
- try to restart your Mac
- Reset AutoCAD to defaults
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 21
info7MBKQ
in reply to: maxim_k
Hi Maxim,
Please see attached I've "Enable dimension input" but still I've got the same issue.
Let me know please how to solve it.
Message 4 of 21
maxim_k
Do you have this issue in all of your drawings?
What command do you use to draw rectangle?
Do you see dimension input when you use PLINE command?
Have you tried to restart your Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 21
info7MBKQ
Do you have this issue in all of your drawings? No, only I've got this issue with rectangle dimensions.
What command do you use to draw rectangle? Don't use any command just click on the rectangle then time the dimensions I want.
Do you see dimension input when you use PLINE command? Yes I do see that.
Have you tried to restart your Mac? I've restarted my Mac and logout still I've got the same issue.
Message 6 of 21
maxim_k
Please provide screenshot of the button you are using.
Plus open Command window (menu Window) and show what you see at the command prompt when you pick on that button.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 21
info7MBKQ
I only can see dimensions when I first open the AutoCAAD as you can see it shows locked. After first use I can't see anything when I type dimentions. Photo1.png
Message 8 of 21
maxim_k
Again:
- Please provide screenshot of the button you are using.
- Plus open Command window (menu Window) and show what you see at the command prompt when you pick on that button.
Another questions:
What macOS version do you have on your Mac?
Why you haven't installed the AutoCAD for Mac 2018.3 Update yet?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 21
info7MBKQ
Please see attached I take a photo of the screen and can't see any dimension size.
It is macOS version 11.3.1 and I've  just installed the AutoCAD for Mac 2018.3 but still the same.
I think it is better if you take some screenshots to guild me what to do.
Message 10 of 21
maxim_k
Hi @info7MBKQ ,
AutoCAD 2018 for Mac is not supported on macOS Big Sur (11.X):
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/sfdcarticles/sfdcarticles/...
So I think this is the problem.
If you have Dynamic Input turned on in drafting settings and use RECTANG command to draw rectangle:
you should see dynamic dimensions after you pick the first point:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 21
info7MBKQ
Which version AutoCAD is for macOS Big Sur? Please provide the link so I can instal that.
I've followed your instructions but nothing is changed.
Message 12 of 21
maxim_k
@info7MBKQ ,
2020, 2021 and 2022 versions of AutoCAD for Mac are compatible with macOS Big Sur.
If you are on subscription, you can download AutoCAD from your Autodesk account
You can also download trial version of AutoCAD 2022 for Mac here:
https://www.autodesk.com/products/autocad/free-trial
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 21
info7MBKQ
The dimension is not picking the right objective as I want, could you please guild me how to solve the issue?
Message 14 of 21
maxim_k
What do you mean?
Elaborate, please.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 21
info7MBKQ
When I try to do measuring dimensions from a particular spot, I don't have control over the dimension, it picks up from where ever the dimension icon wants.
Message 16 of 21
maxim_k
Do you use the object snaps?
https://help.autodesk.com/view/ACDMAC/2022/ENU/index.html?guid=GUID-8F5E5431-9EFB-414E-BC6D-2C65EFB2...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 21
info7MBKQ
Yes, I do want to use the object snaps but it doesn't pick the right object.
Message 18 of 21
maxim_k
Do you mean it doesn't hook correct point on the object?
Do you see OSNAP marker?
Can you provide screencast of what happens on screen?
Do you still use 2018 version?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 19 of 21
info7MBKQ
I use AutoCAD 2022 version.
Yes, I mean it didn't hook correct point on the object but now I've fixed that from (object snap).
Message 20 of 21
Kristey
I have the same problem.
Every time I press TAB, nothing happens...
I use this on windows without any problem.
Technology Administrators
