Can't create a new text style in AutoCAD for Mac
jodecaesteker
jodecaesteker
I have a rather basic question about a simple action: how do I create a new text style in Autocad for Mac?!
I know how I should do it, but when I get the text style dialog box and click the "+" under the text style list on the left, NOTHING happens.
What am I missing here?
@jodecaesteker
john.vellek has edited your subject line for clarity:Can not create a new text style?!!!
0 Me gusta
Responder
Soluciones aceptadas (1)
1.429 Vistas
13 Respuestas
Respuestas (13)
maxim_k
I have no troubles with this:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
jodecaesteker
Thanks for trying to help, but when I click "+" nothing happens for me: I do not get a new text style!
0 Me gusta
maxim_k
Which AutoCAD version do you have and which OS X installed on your Mac?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
jodecaesteker
I'll have to check tonight - I think it's Autocad 2015 for Mac on Yosemite.
The thing is: I had this problem a few months ago and then I found the solution, but I forgot...
0 Me gusta
maxim_k
Please ensure that you have installed last Update for AutoCAD for Mac:
https://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-2015...
If AutoCAD is updated, than try to Reset AutoCAD settings.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
john.vellek
Hi @jodecaesteker,
Please update your post on whether or not your problem has been resolved. I look forward to helping you with this issue.
John Vellek
jodecaesteker
I did a reset (Acad was already updated with the latest update). But... that didn't resolve my problem. I started another file, based on another template and this one DID allow me to add text styles. The file I was working with still doesn't allow me to add text styles when I click on the "+" in the text style dialog box. Maybe it's really file/template related? Can someone from Autodesk confirm?
Anyway, my problem is resolved. Thanks for helping.
0 Me gusta
maxim_k
Try to run AUDIT command in this problem file and repair errors if any.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
john.vellek
Hi @jodecaesteker,
Please attach the drawing and your template file so I can take a look for anyting that might be causing this problem for you.
John Vellek
0 Me gusta
jodecaesteker
Hi, I attached the dwg. For some reason, I can not add the dwt: "The attachment's titleblock.dwt content type (application/dwt) does not match its file extension and has been removed."
Don't mind the language (it's Dutch) - and as for the text: you probably won't have the font I'm using...
Hope you can find the problem.
If not, I can work with the new file I got, but it hasn't got all my layers. Is there a way to get all the layers from my first template into the new one (the one where I can add text styles?)
0 Me gusta
maxim_k
Solución aceptada
Hi jo,
Here is the solution of your problem:
- Open your drawing use STYLE command to open Text Style dialog box
- Rename text style STYLE1 to something different, for example to STYLE-1
- Apply changes with Apply button
- Use + button to create new text style
It appears there is a bug in AutoCAD for Mac which prevents from creating new text style via Text Style dialog if one of the existinf text styles has the name STYLE1
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
jodecaesteker
That's it! I remember now. Weird bug indeed. I'll try tonight and keep you posted!
THANKS - this is a great help!
0 Me gusta
jodecaesteker
That was it. Solved! Thanks for helping in such short notice!
0 Me gusta
