I have an irregular 3D shape and want to make a copy of it with the scale x=0.95, y=0.95, z=1.
Then I want to subtract the copy from the shape (I think it is helpful to mention that I know how SUBTRACT command works).
From what I googled, I can scale each axis differently using block which I managed to do without any problem.
But when I tried to subtract the newly scaled block from the 3D solid shape, SUBTRACT command didn't seem to work.
1) So is there any way I can subtract block from 3D solid shape? or
2) Is there any other way I can scale each axis differently? or
3) Can I change block back to 3D solid shape?
Thanks for the help in advance!
Solved by maxim_k. Go to Solution.
Thank you for the answer Maxim!
I forgot to tell you that I managed to make a cylinder with ellipse bottom and circle top.
Also I solved the problem by taking different a approach.
