Block Sync for Mac?
mzamoraj
Block Sync for Mac?
mzamoraj
Hello, I'm looking to share blocks between devices (Mac and Windows versions of AutoCAD). Is this possible or is an external cloud solution needed?
0 Me gusta
Responder
265 Vistas
3 Respuestas
Respuestas (3)
pendean
Community Legend
Community Legend
As long as all users have access to your source DWG file(s) for those blocks through your preferred access/delivery method (same ones you use to access your own DWG files), you're there.
https://help.autodesk.com/view/ACDMAC/2023/ENU/?guid=GUID-C1551EC5-2B05-423C-A485-0838E325535E
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2023/ENU/AutoC...
HTH
0 Me gusta
mzamoraj
But for starting new projects on one device and being able to access the blocks from my other device?
0 Me gusta
maxim_k
@mzamoraj wrote:
..... is an external cloud solution needed?
Yes, if you want to sync (share with yourself) block library and recent blocks between your devices, you need to use cloud solution:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
