Anuncios
Black box appearing on xref images when plotting
dylan_stoddard
dylan_stoddard
Hi All,
I am running AutoCAD LT 2016 for mac (Version M.48.M.617 Update 3) on macOS Sierra (10.12). I upgraded my MacBook Pro's OS to Sierra when it was released recently. Since updating when I plot layouts in paper space any raster images that were attached to XREF files appear as black boxes. The issue does not occur when printing the same raster images from the reference file in model space.
I've attached an image capturing the issue, a screen shot of my page setup, print dialog, and also pasted below the Plot and Publish Job Complete dialog.
Job: - Plotted
Job ID: 1
Sheet set name:
Date and time started: 9/29/16 12:37:02 PM Eastern Daylight Time
Date and time completed: 9/29/16 12:37:06 PM Eastern Daylight Time
UserID:
Profile ID: <<Unnamed Profile>>
Total sheets: 1
Sheets plotted: 1
Number of errors: 0
Number of warnings: 0
Sheet: - Plotted
File: /Users/dylanstoddard/Google Drive/Pershing Projects/IDB 2014/Andres Bello et al/CAD/SHEETS/AV-001-OTHER SPACES-CAFE-DINING.dwg
Category name:
Page setup:
Device name: HP Photosmart C3100 series - plotted to file
Plot file path: /Users/dylanstoddard/Downloads/test.pdf
Paper size: ARCH E1
0 Me gusta
Responder
Soluciones aceptadas (2)
10.717 Vistas
75 Respuestas
Respuestas (75)
No aplicable
Also having this black boxes on raster images problem, any word on an update or workaround. Reinstalling el capitan is a huge pain in the ****.
0 Me gusta
john.vellek
Hi @Anonymous,
Have you tried Publish instead of Plot or export? The Publish command worked great for me.
What version of AutoCAD are you using?
John Vellek
0 Me gusta
No aplicable
2015 and yes I tried publish
0 Me gusta
john.vellek
Hi @Anonymous,
Have you applied the updates from here?
Unfortunately I don't have 2015 installed on my home Mac.
Are you interested in trying the Public Beta of AutoCAD for Mac 2017? I know it worked for me there as well as in 2016.
Can you send me some sample files so I can see if they publish properly on my Mac with Sierra?
John Vellek
0 Me gusta
No aplicable
No beta 2017 did not work. Images still not showing up and white lines turned out super chunky.
Running Sierra / AutoCAD for Mac 2016/ having the same problems as everyone.
0 Me gusta
No aplicable
I cannot use the Publish command. I have multiple sheets set up in paper space which means we cannot use the Publish command.
please fix this bug ASAP. I am sure it disrupts workflow of A LOT of users.
0 Me gusta
No aplicable
Trying 2017 naboo beta.
Using the print command.
Besides the raster images turned black, all the white (#7) turned chunky. See screen shot.
0 Me gusta
wei503
The raster image plotting issue on Sierra is under research.
Hi @Anonymous,
The issue you reported is different. I cannot reproduce it on my side. Could you please send me a sample drawing and the plotstyle used for the plotting?
My email: wei.ma@autodesk.com
And please note that it is not appropriate to discuss behavior of Naboo Beta in this forum. You can post the findings in Naboo Beta forum:
https://beta.autodesk.com/project/forum/default.html?cap=D0161FC94D2E40199F3A7EED0088B434
Wei
Wei Ma
AutoCAD QA Manager
0 Me gusta
john.vellek
Hi @Anonymous,
Can you share your sheet set and drawings? I am able to publish to PDF just fine with AutoCAD 2016 on Sierra as shown in the screencast.
John Vellek
0 Me gusta
No aplicable
Thanks very strange, I, myself along with many other users would only see black boxes to the extent of the reference within the PDF. I don't have any evidence anymore as I deleted it all. I had to restore my mac to a previous time where I had El Capitan for this to work. I had to do this as soon as possible as I was losing too much money through my business in wasted time. (I actually lost more money than 1 years Autocad LT subscription)
Also, many mac users (along with myself) don't go through the publish process to plot PDFs in Autocad. We simple use cmd+P (print) which is far easier to create a 1 page PDF. I would only use publish for multi page PDFs
john.vellek
Hi @Anonymous,
I am sorry that you have had so much difficulty in getting this to behave. Obviously your software was developed prior to Sierra and it is not yet a supported configuration. It would have been nice to see what was happening on your Mac compared to mine but I guess I will have to wait for another case that displays this issue.
The Publish method was only suggested as a workaround until the defect can be addressed.
I am glad that you are back up and running but as a suggestion, make sure that on the next upgrade, that the configuration has been tested and is supported prior to installing. I like to be on the bleeding edge but I too have to be careful not to impact my environment too much.
Thanks for your patience.
John Vellek
0 Me gusta
No aplicable
You mean give you the autocad file?
0 Me gusta
john.vellek
Hi @Anonymous,
Yes, attaching the cad file along with the corresponding image files would help to nail down the exact cause of this issue. Please share if you can. (Strip out anything proprietary.)
John Vellek
0 Me gusta
No aplicable
Thanks for suggestion John.vellek. I did actually check for updates on autocad LT for mac right after I installed sierra.
One would assume that when you purchase a licence for software named "AutoCAD LT 2016 for mac" that all aspects of the software would be compatible with 2016 Mac OS versions. Clearly not. I understand if there was an unknown glitch in the initial day after sierra was launched, but for this to not have been sorted out by your developers even after a couple of weeks is ridiculous, especially when this software is relied upon by many businesses.
0 Me gusta
john.vellek
Hi @Anonymous,
Bu updates, I mean Operating System upgrades/updates.  Windows users too have been feeling similar pain with the Windows 10 Anniversary update.  Software developed before a new operating system is developed can only be designed and built for the existing operating system.
I know the development team is examining the impact of the newer operating system.
Thanks for your contribution.
John Vellek
0 Me gusta
No aplicable
See attacched CAD file.
0 Me gusta
john.vellek
Hi @Anonymous,
Thanks so much for the files. It is interesting that I can attach the images to a new document and publish them without issue but when I try to print your document to PDF I can duplicate what you are seeing.
I will have to do some more investigation on this issue and will see if I can come up with any other alternatives. for you.
John Vellek
0 Me gusta
No aplicable
Thanks for that. I don't use the Publish command. I use the PRINT command and that's when the raster image issue comes up.
0 Me gusta
No aplicable
I have installed the service pack updates.
Either way I am interested in getting my Autocad 2015 working not upgrading to 2017.
0 Me gusta
No aplicable
I installed a trial version of 2016, it didn't work.
0 Me gusta
