batch publish to pdf bug autocad 2017 lt
raumpunktmp
Message 1 of 11
raumpunktmp
annotative text does show all scales in pdf. some text has frame around it. if sent to printer instead it looks good.
Replies (10)
Message 2 of 11
maxim_k
Do you use SHX fonts in Text Styles in the drawing?
Which application you use to view PDF files? If it is Preview app, than have you tried to open PDF in Acrobat Reader look if the issue with text objects is still here?
Can you attach the resulting PDF file here?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 11
raumpunktmp
thank you for reply.
yes we use annotative romans.shx fonts and preview app for mac. (see jpg with wrong frames and too large text)
there is no problem with acrobat reader.
Message 4 of 11
wei503
Yes, known issue with PDF on Preview app. Please use Acrobat PDF Reader.
Wei Ma
AutoCAD QA Manager
Message 5 of 11
maxim_k
Try to set System variable EPDFSHX=0
Command: EPDFSHX
Enter new value for EPDFSHX <1>: 0
Command:
Then test PDF in Review app.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 11
maxim_k
Have to say that my last reply disables searchable text in a PDF when SHX fonts were used in the originating DWG file.
But if you don't need searchable text in a PDF created from drawing with SHX files, you can turn off this feature as described above.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 11
wei503
This sysvar is not available on Mac..
Wei Ma
AutoCAD QA Manager
Message 8 of 11
wei503
Oops, sorry I was wrong, the sysvar is available on 2017.
Wei Ma
AutoCAD QA Manager
Message 9 of 11
raumpunktmp
hi maxim,
with system variable EPDFSHX=0 it worked.
thank you.
Message 10 of 11
movinghouse
Has LT 2017 fixed the issue of batch publishing to PDF saving at a slightly wrong scale? I submitted a bug report for the last 2016 version (it's been present since 2015 at least) and heard nothing back and hadn't seen an update since.
If I print a drawing, a ruler measurement of the page confirms the scale is correct. If I export to PDF or batch publish to PDF, whatever conversion AutoCAD for mac is using saves a page very slightly larger than the correct scale. It's subtle but throws out all measurements. I can do a hacky fix for a single page by going to print and then using macs own system tools to save the pre-printed page as a PDF. This os built-in conversion to PDF keeps the scale correct. I can't do this for batch PDF.
Message 11 of 11
raumpunktmp
we have no scaling issue with batch publishing to pdf.
