Autocadd 2015 mac to look like windows autocadd
Hi I just recently signed up for an online course for autocadd and i have a mac which has a different layout than the windows version. Would i be able to make the mac version like the windows version? Should I install windows and download the windows version? Or do you think ill be ok using the mac version through out the course?
maxim_k
Welcome to Autodesk Forums!
>>>Would i be able to make the Mac
No, you wouldn't. AutoCAD for Mac has it's own interface. Actually this was already discussed here many times.
>>>Or do you think ill be ok using the Mac
If you are just starting to learn AutoCAD and online course doesn't include information about AutoCAD for Mac features (in interface and other differences) than I'd suggest you to use Windows version for learning.
You can find AutoCAD for Mac and for PC comparsion here:
http://www.autodesk.com/products/autocad/compare/compare-platforms
Also look here:
http://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticles...
At the same time you can find special tutorials about AutoCAD for Mac, Not so much as for PC version, but they exist.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
