Anuncios
AutoCAD Plot style editor, can't add style
jirimeijers
jirimeijers
I wanna set up my own template with specified colors when drawing but I can only use the set colors as is preset.
Is there a way I can do this?
I added a picture to show what i mean.
0 Me gusta
Responder
Soluciones aceptadas (1)
2.672 Vistas
6 Respuestas
Respuestas (6)
jirimeijers
To clarify, I wanna have particular RGB colors as plot style
0 Me gusta
john.vellek
Hi @jirimeijers,
This should certainly be something you can set up if you are talking about AutoCAD Index colors (1-255).  Do you have a color mapping that you want to use? If you can provide on of your files and show me which colors you want mapped I can create a sample video of how this process can be done.  What version of AutoCAD are you using?
John Vellek
jirimeijers
Hi @john.vellek
Yeah I basically want the 1-255 to be changed/ others to be added so I can have different colors
For example I'd like to add this color:
- RGB 255,78,32
Im using AutoCad 2017 on mac
Appreciate the help!!!
0 Me gusta
john.vellek
Solución aceptada
Hi @jirimeijers,
I am actually a bit confused on what you want to do here. In your screen image, you are showing the Index colors (1-255). These can't be changed to a True Color. However, any index color that is displayed on the screen can certainly be mapped to a true color in the plot style.
I made a quick video that shows how to modify a CTB file with one color (Red #1). Instead of having it plot to Object Color, I select the True Color value that you indicated. Is this what you are trying to do?
John Vellek
0 Me gusta
jirimeijers
@john.vellek
Ah, yeah I meant to change an index color.
Weird it's not possible because there are those fields when right clicking.
Well thank you for the help tough!
0 Me gusta
cadffm
Color-dependent plot-style tables (*.ctb) refer only to the index colors,
you want to change objects with TrueColor colors in the plot output,
one must resort to a completely different concept.
Named Plot Style / Plot Style Tables (*.stb) - There is a lot to learn.
The plot styles are COMPLETELY INDEPENDENT of Layer and object colors!
4U => http://help.autodesk.com/view/ACDMAC/2017/ENU/?query=stb
Sebastian
0 Me gusta
