AutoCad Mac LT 2016 - Where is Design Center? need to insert appliances, etc.
So I'm a newbie but not a newly to the technology.  I've been suing you tube and have created an entire floor plan for some as-builts for a renovation i am doing.  Now I need to add the detail.
I cannot find the design center on this version.  Is it not available on LT or something?  I downloaded onto my Mac via the annual subscription service.  I have searched the AD website and cannot find anything.  Maybe I am using the wrong terminology.  I am trying to inset appliances, furniture, plumbing fixtures, etc.  Where and how do I do this??????  Is there not a library that I can simply choose from and insert or do I have to create my own?
THanks,
CJ
pendean
Community Legend
Community Legend
AutoCAd/LT for MAC is so different, many Windows looks and core functions are not there. Look at using the Content Palette. Usage is explained in HELP.
BTW the MAC forum is way over there, worth searching for answers to your next set of "mac is missing..." questions https://forums.autodesk.com/t5/autocad-for-mac/ct-p/3011
Victoria.Studley
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD for Mac forum! (Your post may have been moved over here.)
In addition to what @pendean has said, you might find these threads and resources helpful:
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the resources that @pendean and I provided help you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Yes.  It helped.  I also spoke with a  few Architect buds and they informed me that to build content libraries, I would either have to draw blocks myself, buy blocks, or acquire some other way.  I was hoping to download some free block pallets from AutoDesk - simple ones that have appliances, door types, plumbing fixtures, etc.  But I cannot find them.  I also learned that my buds all draw on PCs and not Macs.  I may buy the Windows Parallel and run auto cad on it.
Victoria.Studley
Hi @Anonymous,
Thanks for circling back.
You might find the resources in the following article helpful if you're looking for more block content:
I hope this helps point you in the right direction! Smiley Happy
Victoria Studley
dgorsman
Most of what you'll find won't meet client standards and will need some tweaking.  Normal procedure would be for clients to provide the blocks to work on their drawings, so everything is consistent.  After a while you'll get a handle on what's needed and/or typically missing and start to accumulate your own for when clients don't supply anything.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
