Anuncios
AutoCAD Mac 2021 Export PDF
David_Stacey
David_Stacey
Hi guys. So I just installed AutoCAD Mac 2021. In previous versions it was possible to export to PDF by Command+E keyboard combination.  In the 2021 version this doesn't work - you need to go through the Print/Plot dialog.
What this means is for multi-layout plans I need to output each layout manually then merge them manually in Mac OS Preview (or similar) - in my opinion this is a backwards step!
My question therefore is - Is there is a way to automatically output a PDF containing all layouts?
Thank you in advance
David
0 Me gusta
Responder
Soluciones aceptadas (1)
1.881 Vistas
8 Respuestas
Respuestas (8)
maxim_k
Solución aceptada
Hi David,
Yes, in 2021 version PDF option was removed from EXPORT command dialog.
If you want to export multiple layouts from drawing to PDF, you van use Batch Publish feature - PUBLISH command:
https://help.autodesk.com/view/ACDMAC/2021/ENU/index.html?guid=GUID-BBBA8D8F-7C3C-4A8D-A581-9223D961...
https://help.autodesk.com/view/ACDMAC/2021/ENU/index.html?guid=GUID-0D1DB83F-F1A3-4D22-8FBC-342B2E93...
Menu File -> Batch Publish, or command alias - BPUB
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
David_Stacey
Thanks Maxim
That's great... guess I was confused by the 'Export to PDF...' under the File menu.
Appreciate your quick response! Cheers!
David
guy.foord-kelcey
Community Visitor
Community Visitor
This still feels like a backwards step, this alternative method takes many more clicks to achieve the same result. Can't help but feel that this a bug not a feature as there is a 'blank' option in the 'Export…' dialog box, where 'PDF' used to be.
0 Me gusta
maxim_k
Welcome to Autodesk Forums!
Hi @guy.foord-kelcey,
I think "'blank' option in the 'Export…' dialog box" is a bug, but not the absence of Export to PDF option, because on this Help page:
https://help.autodesk.com/view/ACDMAC/2021/ENU/?guid=GUID-A72DB257-3410-4792-B548-6B9FC1DED72B
you can see: "Note: Use the PLOT command to output a drawing to PDF."
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
David_Stacey
Totally agree with this... it's a backwards step. Previously I could
Command-E and then click on Save to export a PDF (single or multiple
layouts). It now requires far more clicks to achieve the same results
through Batch Plot. Disappointed this workflow has been removed by Autodesk!
clweller
Totally agree with this. I used Cmd+E for export multiple layouts to a PDF many times a day. This is a critical feature loss, and it needs to be brought back.
0 Me gusta
pendean
Community Legend
Community Legend
Tell Autodesk all about it right here https://www.autodesk.com/company/contact-us/product-feedback
0 Me gusta
David_Stacey
I've provided my feedback on this issue as well as the ridiculous "Plot Complete" window. After every Mac release, I've asked for the Plot Complete window to be removed - no other software does such a thing. If Autodesk needs such a feature internally then it should provide a switch to turn it off or have it as a debug feature only. I don't think Autodesk really listen to their customers on many issues.
