Autocad LT on a Mac
Autocad LT on a Mac
Autocad LT on a Mac
I'm the admin to Autodesk, not a Mac user
After installing 2017 LT on the MAC we get a couple issue pop up.
1.Missing SHX Files - the help files only tell you how to fix on a windows computer.
2. unsupported objects- image attached.
3.Design Objects are really different on a MAC
pendean
Community Legend
Community Legend
You need the missing SHX font files from the file creator: ask them.
AEC objects from verticals require you to ask the file creator to "EXPORT TO AUTOCAD" the file so you can use it: they are likely usign AutoCAD Arch, MEP, Civil3D or Map3D. Ask them. There are no Object Enablers for MAC users.
maxim_k
And OLE is not supported on Mac at OS level.
So ask the creator to attach the image file as external reference.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Hi @ trowbridge,
Were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Sarah Emmsley
Technical Support Specialist
Emmsleys
@Anonymous,
Please feel free to post back if you still run into an issue with other files or you need additional support on troubleshooting this issue.
Thanks.
Sarah Emmsley
