- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @luda72,
Welcome to the Forums.
I need a bit more information to better address your problem.
What product release are you using? and what are your system specs? WIN 7 , 10? Graphics card?
Has this been an ongoing problem or a new issue?
Thanks.
What AutoCAD LT release? 2015,2016,2017?
Windows 7, 8, 10?
You can try the following;
Let me know if you have any other questions.
Hi @luda72,
It would be helpful if you answer the two questions that have been asked previously as well.
What product release are you working on ? 2015 or 2016 or 2017?
What are your system specs? WIN? Graphics card?
It helps myself as well as other community members when evaluating and troubleshooting this thread.
Did applying the service pack for your AutoCAD 2014 release help?
If you are still having an issue with opening AutoCAD LT post back and we can continue to troubleshoot the issue.
Thanks.
Hi @luda72,
You could try using the steps suggested in the AKN article: How to Remove Autodesk A360 on PC and Mac.
Post back should you have any other issues.
The problem to connecting to the license server can happen for a number of reasons.
Autodesk servers could be temporarily down, if this was the case and it happened for a long duration of time then you would see a lot of movement within the community forums about it. For the most part the servers being down is temporary. In most cases it'll be back up and running within the day.
Other reasons could be;
If this does happen again and you can't connect create a new post and we can continue to troubleshoot.
Thanks.
