Anuncios
AutoCAD LT (MAC, 2022) Project Manager
Chris-Steelex
Chris-Steelex
Hi, I have just started using the project manager and it seems to have a lot of great features, this is on LT MAC 2022
However, I have an ongoing problem that when I start AutoCAD up the Project Manager is frequently blank, I start the project. If I reset AutoCAD it then works fine, when I close the program I then, on most occasions get the blank project manager again and have to reset again.
Any suggestion will be very helpful, thanks.
Chris,
0 Me gusta
Responder
600 Vistas
4 Respuestas
Respuestas (4)
steven-g
There is a dedicated forum for MAC over here, you would be better asking there.
0 Me gusta
maxim_k
Hi @Chris-Steelex ,
At first try to install AutoCAD LT for Mac 2022.1 Update, which was released today. Use "Check for Updates" from menu AutoCAD.
If this will not fix the problem you may try to Clean Uninstall AutoCAD LT for Mac as described here:
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/sfdcarticles/sfdcarticles/...
and here:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Clean-uninstall-of-Autod...
Then install AutoCAD again and apply 2022.1 Update.
Just in case - please specify macOS version installed on your Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Chris-Steelex
Thanks, update installed and will see if it solves the problem.
0 Me gusta
Leaf.chai
Hi Chris,
It seems that your Project Manager palette shows as blank after restart?
So can I ask you some questions for this issue?
1) Can you repro this issue on any legacy version, or just in 2022 LT?
2) Which Mac OS are you using?
3) Are you using the Duel monitor? If yes, AutoCAD is placed on which screen. 1st or 2nd?
Leaf
Leaf Chai
AutoCAD QA Analyst
0 Me gusta
