AutoCAD LT keeps opening Help website internet while I'm working
jacksonvanmatreT52Z7
I was wondering if there is any way to turn off a setting in AutoCAD to prevent it from opening the internet help website when I've slightly mis-hit my keyboard or mousepad. I'm in the middle of working and will slightly tap my mousepad or my keyboard and it will open up Safari to the help website. I don't need help, and then, by the end of my work session, I have like 80 tabs open on the help website, because it won't stop. Is there a setting I can just turn off connecting to the help website?
0 Me gusta
Responder
1.850 Vistas
15 Respuestas
Respuestas (15)
maxim_k
Welcome to Autodesk Forums!
Hi @jacksonvanmatreT52Z7
Do you mean you frequently hit F1 key or Help button on Touch Bar (if you have Touch Bar on your Mac and use it with AutoCAD) by mistake?
I yes, then it is possible to assign other then Help command to it.
What AutoCAD LT version do you have on your Mac?
Do you have Touch Bar on your Mac? If yes, is it enabled for AutoCAD?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Hey Maxim,
Thanks for your quick reply! I have AutoCAD LT 2021. I do also have the touchpad at the top of my keyboard. I find it happens a lot when I'm dragging something on my trackpad in my drawing, or sometimes when I'm right clicking. I can't even pinpoint when it's happening specifically, but I will just be in the middle of a command and it will open Safari. It does usually center around using my trackpad, I do know this. It just constantly opens the homepage for AutoCAD LT 2021 for Mac Help.
0 Me gusta
maxim_k
So, you don't touch Help (or F1) button on Touch Bar when Safari opens with AutoCAD Help. Am I correct?
Do you mean you move objects in the drawing? Or just panning around with Trackpad with two finger drag?
What options do you have enabled for Trackpad in macOS System Preferences?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
Correct! I definitely am not hitting those. Which is the weirdest part!
0 Me gusta
maxim_k
Do you have any special software for Trackpad installed on your Mac? Something like BetterTouchTool?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maxim_k
...and you haven't answered another questions:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
darby
Observer
Observer
I am having this same issue on my new Macbook Pro with M1 chip. It is incredibly frustrating.. Did you ever figure out how to resolve this issue?
Thanks in advance.
0 Me gusta
maxim_k
Hi @darby ,
This topic is old enough and  @jacksonvanmatreT52Z7 have not answered all my questions here.
Can you provide more details about your problem?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Hello!
have the same problem. It keeps opening Help website randomly while I'm working...
I'm using MacBook Pro '16, Big Sur. AutoCad 2022.
0 Me gusta
maxim_k
Hi @Anonymous ,
Do you press any buttons on your keyboard before the help page opens?
Which Help page opens?
Do you have secondary mouse click configured to repeat last command?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Just loaded AutoCAD 2020 LT for Mac on a MacBook Pro 2020 running Big Sur 11.6 and this is also happening. I have a touch strip with no modifying apps or settings. Very annoying. How do I shut this off!??!?!?!?!?!
0 Me gusta
maxim_k
Hi @Anonymous ,
I can repeat my questions, I asked @Anonymous :
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Yes, command buttons: L, PL, TR, MA... It happens randomly. It opens help page explaining commands. Didn't happened latelly so can't tell you exactly which ones or is related to the command buttons i pressed.
No, don't have secondary mouse click configured to repeat last command.
maxim_k
Looks like something force AutoCAD to call 'HELP command inside other commands.
Not sure what it is though....
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
I believe I've solved it? I think this was user error! And kinda silly UI?
By default, the Touch Bar is set to change to change its functionality with
whatever app is open. In the case of AutoCAD, the "Help" icon is set to be
at the far left of the Touch Bar, right next to the ESC button (worst place
ever...) Like many users, I often have my left hand hovering somewhere
around that area and I think I may have been passing a finger close to the
Touch Bar which was setting off the Help icon.
I went to Preferences and changed the Touch Bar so that it no longer
changes per app, but always just displays a "Expanded Control Strip" which
is similar to the previous Macbook type strip (Brightness, Gather Windows,
etc).
So for now, it's been better-- try changing this setting and seeing if it
solves the issue? I'll keep an eye on this as well.
0 Me gusta
