Autocad LT 2022 for MAC - Right-click menu doesn't show
alabrk
alabrk
Hello everyone,
I have used the right-click shortcut menu forever and the shortcut always worked. I searched other posts with the same problem but the solutions provided did not work for me...
I have changed the PICKFIRST to 1 and the SHORTCUTMENU to 11 ( it already was on default settings) as mentioned but it doesn't change a thing.
Can someone help with this matter... I feel handicapped without this shortcut menu.
Thank you!
0 Me gusta
Responder
Soluciones aceptadas (1)
527 Vistas
6 Respuestas
Respuestas (6)
maxim_k
Hi Ariane,
What happens when you right-click?
Does AutoCAD repeats last used command?
Is right-click shortcut menu not available in all situations (outside command, inside command, with or without selection)?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
alabrk
Nothing happens.
Right-click shortcut menu is not available in all situations (outside command, inside command, with or without selection).
0 Me gusta
maxim_k
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
alabrk
The same thing as a left click. When I select, click M (move) and then try to right-click, the object moves as it would normally do with left click...
0 Me gusta
maxim_k
Solución aceptada
If you don't have any special mouse software, I think you need to check that right-nouse click is enabled in Mouse pane of macOS System Preferences.
If it is enabled, then try this:
1/ Relaunch AutoCAD
2/ Restart your Mac
if above will not help -
3/ Reset AutoCAD LT to defaults (menu AutoCAD -> Reset AutoCAD (you will loose all your customisations in this case).
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
alabrk
OH! That was it. I didn't think about that. Thank you!
0 Me gusta
