Anuncios
Autocad LT 2017 mac error on startup
LormansDesign
LormansDesign
On my office computer a Mac mini 2009 I have Autocad LT 2017 Mac running without issues for a couple of weeks.
On my home laptop Macbook pro 2009 Autocad LT 2017 runs for a couple of days and than out of nothing I get the folowing error on startup:
"Exception in AcExperience.bundle ARX command"
Both systems run on Mac OS X el Captina 10.11.6
The first time I did get this error I couldn't really find a solution online,
So I did an un-install by the app, and a reinstall the problem still was there. Afther that I tried a un-install and manualy trow away all tempory files in the "aplication support" location for 2017. But i'm not planing to do this every other day on my Macbook pro.
I did some minor modifications on the toolbars: less buttons for almost every bar on de left side. and made my own bar for the measurement tools
I only get the option to click OK on the message's and than Autocad doesn't respond anymore.
Is there anybody with the same problem and/or a solution?
EDIT:
I found a solution to get Autocad LT 2017 Mac working without a reinstall:
You need to delete the following folders In the appliction support -> Autodesk folder:
"2017" in "ACDLTM"
"2017" in "ADUT"
"AutoCAD LT 2017" in "Web Services"
Don't know if deleting one of these would do the trick as well but it works without a reinstall now. (still curious what makes autocad give this error.)
Responder
1.822 Vistas
8 Respuestas
Respuestas (8)
lionel.bekale
Hi LormansDesign,
Welcome to the AutoCAD for Mac forum.
I have seen your post today. I understand that you got the following error message when AutoCAD starts.
<<AutoCAD for Mac error : "Exception in AcExperience.bundle ARX command">>
You also fixed the problem later by deleting the following folders In Library/Application Support/Autodesk folder:
"2017" in "ACDLTM"
"2017" in "ADUT"
However, when you uninstall the software on the Mac you should do the following:
Exception errors in ARX command can be due to damaged file within AutoCAD or due to some ObjectARX applications that do not load properly. Therefore, re-installing AutoCAD as described above may also fix it. Please have a look at this help document ARX (Command)
Hope it helps.
Lionel Bekale
Technical Support Specialist
Link Name
0 Me gusta
No aplicable
I dont know how you guys got this solution to work. It wouldn't work for us, and we're dead in the water now.
0 Me gusta
john.vellek
HI @Anonymous,
Can you tell me which OS you have on your Mac and the exact version of AutoCAD you are running (type ABOUT at the command line)
John Vellek
0 Me gusta
No aplicable
Mac OS Sierra Version 10.12.6
AutoCAD LT 2017
0 Me gusta
lionel.bekale
Hi Paul,
Have you installed all the updates below for this version?
Could you also let us know if you still have the issue described by LormansDesign?
Lionel Bekale
Link Name
No aplicable
Thank you and excuse the Dely in my response… when I left yesterday it had the message and when I got back in this morning it worked perfectly… no idea but happy its sorted; thanks for your help.
0 Me gusta
maxim_k
Hi Paul,
Looks like AcExperience.bundle is a part of the Customer Involvement Program (CIP), which periodically sends data about AutoCAD experience to Autodesk. Maybe sometimes it stops working properly for some reason, then you get an alert you mentioned in your initial post.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
lionel.bekale
Hi Paul,
Thanks for your update. I am glad it works fine now.
Please accept one of the posts as solution if possible and feel free to ask a new question
Lionel Bekale
Link Name
0 Me gusta
