Hi
I write 1st time so hello :).
I have similiar problem, but with AutoCad form Mac 2014 and 2015 (not LT) edu ver.
100+ CPU usage
Since 1 month ago I drawing on AutoCad for Mac 2014 about 1 year
I had
MacBook Air
i7 1,8 4 cores, 4GB Ram, SSD, Intel HD Graphics 3000 384 MB.
I had many slowing problems. Slow reaction for many commands, slow work generaly on bigger dwg’s with some hatches, solids, pdf’s imported, etc.
I thought to my self, the reason is for shure hardwere. So I bought:
Mac Pro 5,1
3,46 GHz 6-Core Intel Xeon, 24 GB 1333 MHz DDR3 ECC
, SSD (as fast as in new „black tubes”), AMD Radeon HD 7970 3072 MB.
Imagine my confused, when I did not see big change.
I bought it also to fluent work on many apps in the same time (Pages, Preview (on large pdf its terible to view some arch maps or large drawings, i thought that problems with viewing and eiting in Preview and Pages will apear, but not), Mail, Numbers, iPhoto, Safari)
I write about many apps, becouse maby OSX is not multitask as I expect?!?! I dont know
Problem I had on MacBook Air on AutoCad form Mac 2014 and also on 2015
Slow work generaly
Many many many times craches on very simple commands (I always screened crashes and send to autodesk)
Many times hangs for qouple of minutes or even some times half an hour and finaly i had to „hard close”.
Very slow swithing betwin layers and model
Problem now on AutoCad for Mac 2015
Long opening layer list (command+4)
When open, lasy writing layer name to filter (i write in 1 sec., and waiting about 3 sec to see what I wrote and see reaction (anyway i saw such thing on Pages on Air and on Pro in bigger docs)
Little but confused pauses between pan and zoom commands on Model space, and much longer on Layer space on large paper sizes (on my old Toshiba on PC i dont remember such things on 2d drawing. Only on 3d). Maby is it becouse i set my layouts on 300 DPI and had 100 x 70 cm, but i bought good hardwere to solve these problems
I of course switched Open GL.
I tryed to repair my dwg’s many times during make some project (i mean AUDIT; PURGE; All explode; Save as DXF12) and it didnt help.
I have these problems on dwg’s started on Mac (not on PC)
My ideas
Is it posilble, that layers name are problem. I have in all layers text: „ŁO A …..”
Could be the problem? First i asking, becouse its a lot of work to change all layer names
Could blocks be the problem? As i said, i tried expolde all and it didnt help (mayby a little but wasn't enought fluent), but maby my observing was wrong (You know, testing AC is not my job i do this on side). What is Your opinion about it?
My other questions:
1. How can I export / import my interface from one Mac to onother and from one AC2014 to onother AC2015 on the same comp.?
2. Can i import list of layers from some editable format like simple notepad or excel?
