Autocad for mac - lisp to change floors
No aplicable
Hi guys, I have this lsp to quickly change and copy things from one floor to another. You first write the command PISOS to set the distance between floors in your paper space (for example 500) and the when you write the command UP or DOWN it changes floors. CU to copy UP, etc.
Does someone have an equivalent lsp that works in Autocad for mac?
Thanks!
0 Me gusta
Responder
Soluciones aceptadas (1)
875 Vistas
3 Respuestas
Respuestas (3)
maxim_k
Solución aceptada
Welcome to Autodesk Forums!
Hi Maria,
I don't see anything in your AutoLISP routine which can prevent it from using in AutoCAD for Mac, except this strings:
(DEFUN setstline (/ stline)
 (get_imf)
 (SETQ
   stline (STRCAT
     "MAT PISOS: "		"$(RTOS,$(GETVAR,USERR1),2,0)"
     " - OSNAP: "		"$(getvar,osmode)"
     " - LTSCALE: "		"$(getvar,ltscale)"
     " - PSLTSCALE: "		"$(getvar,psltscale)"
     " - IMAGEFRAME: "		"$(getvar,useri5)"
     " - PROJECTNAME: "		"$(getvar,projectname)"
 (SETVAR "modemacro" stline)
(setstline)
I commented these lines in the routine and attached it to my post.
Can you test it now?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Oh that works, that you so much Maxim!
0 Me gusta
john.vellek
I am glad to hear that it worked. I’ve just accepted the response to your post as a solution so that others can benefit from the information.
In the future, please click on the ‘Accept as Solution’ button if/when relevant. Please feel free to let me know if you have any questions or concerns!
John Vellek
0 Me gusta
