AUTOCAD for Mac lagging after every command
mmi11s
mmi11s
Downloaded AUTOCAD for Mac 2025 onto my MacBook Pro 14-inch, 2021, with 32 GB memory last month. Everything was working smoothly up until last week. Now every time I select a command it lags uncontrollably to the point where I can't use it anymore. Zooming in and out runs smoothly, but when trying to draw a poly line or dim line, for example, it starts to lag. This happens even on new drawings now.
I've tried all the 'fixes' I could find online but nothing seems to work. I've tried:
AUDIT
PURGE
RESET CAD
DOWNLOADED CAD 2024 (still have the same issue)
DELETED RECENT BLOCKS
UPDATED COMPUTER
RESET COMPUTER
I also made sure my computer never uses low power mode on system settings. The only thing I can't figure out is the GRAPHICSCONFIG command, I don't have an option to turn it on or off? I am new to CAD so I could be missing something really obvious. Please help! Thanks :cara_con_una_leve_sonrisa:
0 Me gusta
Responder
657 Vistas
7 Respuestas
Respuestas (7)
pendean
Community Legend
Community Legend
What is your MacOS please?
And what changed with your setup or where you store files or how you back them up or your OS/Updates since last week?
0 Me gusta
maxim_k
Hi @mmi11s ,
In addition to @pendean questions:
Do you use Geometric Constraints in your drawings?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
mmi11s
It's macOS Sonoma version 14.4.1.
I changed how my files were stored post this lagging issue to see if it would help - it was previously stored on my iCloud but I changed it to my computer to see if it was a network issue but nothing helped.
0 Me gusta
mmi11s
Hi, yes I have just the basics active:
Endpoint
Midpoint
Centre
Extension
Perpendicular
0 Me gusta
maxim_k
Endpoint
Midpoint
Centre
Extension
Perpendicular
I think these constraints may be the reason for the lags.
Try to remove them all and don't use at all.
Do you see lags in this case?
EDIT:
Just thought: Do you really mean Geometric Constraints?
Maybe you're talking about object snaps?
Can you share one of your drawings in which you observe the lags?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
mmi11s
I was talking about object snaps, my bad! Just deleted geometric constraints and nothing changed, still lagging as usual. I also tried using an external mouse to see if it was a trackpad issue but still lagging just as much. However, I used AUTOCAD on a separate computer and the drawings were fine? So it confirms that the issue is with my computer specifically and not the drawing. I'll attach a drawing anyways to see if I'm missing something.
0 Me gusta
maxim_k
Hi @mmi11s ,
There is nothing special in your drawing. I used AUDIT command and it found 15 errors in the drawing database, but I'm not sure that these errors could affect AutoCAD performance.
Do you use external references? I see one Xref, but it is unreferenced (= erased).
Can you remember what happened during this time on your Mac?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
