AutoCAD for Mac incredibly slow on M1 with iOS big Sur 11.5
Message 1 of 31
Does anyone have an advice how to make AutoCad LT 2022 work properly on M1 macbook pro with iOS big sur 11.5 on it? It´s just impossible to work normally when Autocad starts to "rotate that colorful ring" after every command!! thanks a lot in advance!
Replies (30)
Message 2 of 31
maxim_k
Welcome to Autodesk Forums!
Hi @Anonymous ,
Do you have any blocks on Recent Blocks tab of Blocks palette?
If yes, try this:
- right-click inside Recent Blocks tab of Blocks palette and select "Clear All" from context menu.
Now test AutoCAD.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 31
didn't help at all.. it's not an issue with blocks.. i also tried to install the whole program (autoCAD) again but it didn't help.. any other ideas please? can´t work like this.. every single command needs "it´s time" - moving text, drawing single line.. everything! and in all files which I open.. what could help please??
Message 4 of 31
maxim_k
Hi Ivana,
I don't have problems with AutoCAD 2022 on Mac mini with M1 chip (Big Sur 11.4).
Didi you have this issue before upgrading to 11.5?
Do you have the problem from the beginning (on first install)?
Do you have the problem in all of your drawings? Even in newly created with a couple of lines?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 31
Hi Maxim,
thanks for your concern. Yes, it was also with previous version of BigSur, but after uprading to 11.5 I think it´s even worse. After first initial install of the program at the beginning it worked ok, but just maybe 2-3 weeks..? than it started to slow down.. Yes, I have tried to open several drawings, the same problem everywhere - waiting after every command to continue..  I also tried to open a new drawing (it took also ages) and tried to draw single lines and objects - that worked normally..
Message 6 of 31
maxim_k
Did you create those drawings with slow downs yourself, on AutoCAD LT for Mac?
Can you share one of your drawings?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 31
maxim_k
Another check:
- close AutoCAD completely with QUIT command
- restart your Mac
- disconnect from Internet and network (if any) - cable or Wi-Fi
- launch AutoCAD and test one of your drawings
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 31
maxim_k
Ivana,
I received your drawing and don't have any visible slow-downs in it.
But you forgot to mention that drawings you are working on have external references attached.
Now I have two another questions:
1/ Where these references are storied? Locally or on network drive?
If they are stored on network drive, then there could be a problem with network and AutoCAD.
2/ I also noticed that you use PDF underlays in your drawing. And I want to say that this is not a good idea. PDF underlays slow down AutoCAD significantly. If you use PDF underlays, I'd suggest you substitute them with raster images. Just save PDF files as JPEGs in Preview app and attach JPG instead of PDF.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 31
thank you Max, but I had an MacBook Pro (Early 2015) before with autoCAD 2017 on it and never had any problems like now - with obviously faster macbook M1 and newer autoCAD on it.. all the references are stored locally on the computer..
Message 10 of 31
maxim_k
I see - they are stored locally.
Are they inside your Home folder?
And what about PDF underlay?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 31
yes, all the references are stored/saved locally. we work with pdf-underlays quite often and it has always worked like that - even if you unload all the references it doesn´t improve anything at all
Message 12 of 31
maxim_k
I still have not installed macOS 11.5 update and cannot be sure if this Update can affect AutoCAD for Mac.
But I think that it is more likely no than yes.
Have you worked with your drawings on macOS  11.4?
If yes. Did you have this slow-downs?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 31
maxim_k
BTW, have you installed the last Update to AutoCAD LT 2022?
This one:
https://knowledge.autodesk.com/support/autocad-lt-for-mac/downloads/caas/downloads/content/autocad-l...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 31
yes, that´s why I thought I should upgrade the iOS - that it might help but it didn´t..
Message 15 of 31
maxim_k
Sorry, you answered yes, but did not specify which question 😞
I suppose the answer was about mcOS 11.4
So what about AutoCAD LT for Mac 2022.1 Update?
And - can you tell about your MacBook Pro specifications? (exact model, RAM)
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 16 of 31
yes, Maxim, sorry - the answer was about upgrading the iOS from 11.4 to 11.5
yes, I have tried that update for AutoCAD as well.
my macbook pro: MacBook Pro (13-inch, M1, 2020),
Apple M1 chip, memory 16gb, startup disk: Macintosh HD
Message 17 of 31
maxim_k
Your Mac should be fast enough.
Unfortunately I cannot fully test your drawing unless you create transmit package with all xRefs and underlays in it.
If you can create such package, you can send me a link in PM, I'll try your drawing on my Mac mini tomorrow.
For the moment I can't guess what the real problem might be....
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 18 of 31
wei503
Hi @Anonymous,
I just sent you an email checking if you are available for a remote meeting to investigate the issue. Let's contact in email for details if you can join a meeting.
Wei
Wei Ma
AutoCAD QA Manager
Message 19 of 31
Hi wei503,
thank you for your concern and excuse my late reply. I would highly appreciate your help because the work in autoCad is incredibly slow, it takes ages until I open 1 file, all the commands work really slow, it's not very convenient help for work. Now I have the actual version of Big Sur 11.5.1.
Thanks a lot in advance, ivana
Message 20 of 31
wei503
Hi @Anonymous ,
I haven't received your reply in the email. I sent to your gmail box. Let's use email to set up a remote meeting.
Please let me know if you did not see my email.
Wei
Wei Ma
AutoCAD QA Manager
