AutoCad for Mac: Architectural units
No aplicable
I cant seem to put my units into architectural units, does anyone know how to do this for autocad for mac?
0 Me gusta
Responder
Soluciones aceptadas (1)
2.233 Vistas
4 Respuestas
Respuestas (4)
No aplicable
Use the Drawing Setup Utility, which is built into AutoCAD Architecture and MEP:
  1. Click the Application icon in the upper left.
  2. Select Drawing Utilities > Drawing Setup.
  3. Under the Units tab, in the Length section, adjust the Type dropdown.
    Drawing Setup Units
0 Me gusta
RobDraw
You could try asking in the AutoCAD for Mac forum, if that doesn't solve your problem.
Rob
0 Me gusta
pendean
Community Legend
Community Legend
MAC forum is over here https://forums.autodesk.com/t5/autocad-for-mac/ct-p/4051
Remember to tell everyone there your exact AutoCAD for MAC year version.
0 Me gusta
maxim_k
Solución aceptada
Welcome to Autodesk Forums!
Hi Abdool,
On Mac you can set Units to Architectural with menu Format -> Units:
For dimensions you need to edit dimension style (menu Format -> Dimension Style):
Select dimension style you want to use for dimensioning, use "gear" menu to modify dim style:
On Primary Units tab select Architectural units:
Don't forget to set dimension style you just edited as current:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
